SolaraGuy.com • View topic - Leaking head gasket
Leaking head gasket
Leaking head gasket
Postby HKSV6SLE » Sun Nov 23, 2003 1:40 pm
i just found out that my head gasket is leaking. It's not leaking bad but it is leaking. So do you guys think it's worth fixing or not? i probably won't have this car more than another year at the most, then im probably gonna trade it in. IF it's worth fixing , anyone have any ideas how much a new gasket is gona cost? And also how many people have had this problem with the head gasket?
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby TadS » Sun Nov 23, 2003 4:36 pm
Gasket = Cheap
Labor = Expensive
On my old car, which had a 3S-GELC, it was about 40 quid for the gasket then about 800 for the labor. I would get it fixed. I image these sorts of things start small then get worse with time. Don't want to accidentally warp the head or something :(. Good luck on getting it fixed.
TadS
Postby HKSV6SLE » Sun Nov 23, 2003 4:53 pm
quid? that a currency from the Uk right? yea i had a feeling that the gasket itself would be cheap but fixing it would be a bitch...
www.lexusnet.com
HKSV6SLE
Postby Mole » Sun Nov 23, 2003 7:02 pm
i had a gasket leak as well. where is the leakage? mine was under the oil cap, small compartment that just made more and more deposits over time. fortuneatly for me, the car was still under waranty at thge time
Postby HKSV6SLE » Sun Nov 23, 2003 10:33 pm
yeah that sukcs cuz i've had my car since early 99 and i have almost 90K now....
www.lexusnet.com
HKSV6SLE
Postby xtychx » Mon Nov 24, 2003 1:43 am
whip out the haynes manual :)
-xtychx
xtychx
Postby adam2562 » Mon Nov 24, 2003 9:47 am
my car has 131k on it and i havent had to replace the head gasket or any seals. yet... somehow my car is taking all the miles fine and i race it a lot!!!
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby adam2562 » Mon Nov 24, 2003 9:48 am
havent had to replace it i meant
adam2562
Postby HKSV6SLE » Mon Nov 24, 2003 1:41 pm
well maybe you just got lucky...i stopped driving my car hard about 30-40K ago...and now i have a leaking seal, i used to abuse my old camry but it held up fine...i guess you just got lucky :P
www.lexusnet.com
HKSV6SLE
Postby kubi » Mon Nov 24, 2003 2:18 pm
Or else you are unlucky :)
Please stop humping my car, owner privilege!
kubi
Postby HKSV6SLE » Mon Nov 24, 2003 11:31 pm
yea probably...
www.lexusnet.com
HKSV6SLE
