SolaraGuy.com • View topic - Just bought real HID system!!!
Postby Jay » Tue Jul 30, 2002 9:59 am
Yes, these are real HID system off from Lexus IS300 for $160.
I can't wait to install it! I need to modifiy my headlight housing a bit....
I will post some pics once finished.
-19" Konig Tantrum rims.. Sitting in the garage waiting for tires..
-TRD springs.. Sitting in the garage waiting for struts..
-Conrero aluminium foot pedals.. Sitting in the garage due to my laziness.
Jay
Postby Guest » Tue Jul 30, 2002 1:10 pm
Please post in DETAIL what all work went into making that work, I know i'm intrested, but i want to see results before i venture out...thanks!
Guest
Postby 20SoLaRa02 » Tue Jul 30, 2002 4:32 pm
good luck and please post pics and detail on work done....good luck again
20SoLaRa02
Postby Jay » Tue Jul 30, 2002 5:14 pm
I am hoping to put them in this weekend. I will definitely post some pics.
Until then stay tuned!
Jay
Postby Jay » Thu Aug 01, 2002 9:22 pm
I am almost finished!! But I have a wiring problem... Maybe one of you can help me out!!!
On the right side, there are three wires to the headlight. red/blue, red/black, and red/white.
On the left side, there are four wires. red/black, red/black, red, red/white...
I hooked red/white on + side of my ballast and red/black on - side.
The problem is that only my left side(driver side) comes on. I checked my right side ballast and bulb with my left side wires and they work fine....
My question is what is that red/blue wire on right side?
I will post some pics once I finish them...
Jay
Postby Jay » Tue Aug 06, 2002 11:27 pm
Alright folks...
My digital camera sucks really bad... I can't seem to capture the night pics... I have a manual shutter camera, and I will take some more pics with that soon... But here are some progress pics.
Ballasts and bulbs from Lexus IS300. I got these from ebay for $157.
Left bulb is the H4 factory bulb and the right bulb is Xenon D2R bulb
Obviously some modification was necessary to fit D2R bulb to the headlight housing...
I used Dremel to cut off the retaining plate from the factory H4 bulbs.
Here is the picture of D2R bulb with the retaining plate on.
This picture doesn't do the justice... The lights are white/blue, not purple.
I will take some better pictures soon.
Go to http://faq.auto.light.tripod.com/headlight-menu1.htm to read about some FAQ before you do this HID conversion...
H4 bulbs only use the upper portion of the headlight reflector for the lower beam, so you must fabricate some shield so that the HID lights can't reach the bottom portion of the headlight reflector.(I made one out of beer can!! Pics coming soon) It will only create stray lights, which are aimed upward and it will annoy on coming drivers...
Jay
Postby Jaimster » Tue Aug 06, 2002 11:32 pm
Ooooh, real HID! Very Kewl! :o
Hey did you do the fogs too?
Jaimster
Postby Missay » Tue Aug 06, 2002 11:33 pm
very sharp...I'm guessing you figured out the wire dilema??
Melissa
Missay
SolaraGuy Ambassador
Postby Jay » Tue Aug 06, 2002 11:41 pm
Yeah... I figured out the wiring dilemma.. I read up on the Haynes manual!! Actually I figured out their electrical diagrams....Pain in the A$$.
One more thing.. Because HID requires 15 Amps to start up the bulbs, it needs separate wirings. If I keep use the factory headlight wirings, I am going to fry them soon or later... So, I am going to make my own with thicker wires and relays... Go to that website I posted earlier, they have "how to" diagrams! Easiest way would be buying expensive already packaged HID kit.. They come with everything you need. But they are pricy....$400..
I put my labor in but I only spent $160... :)
Jay
Postby Kenn157 » Wed Aug 07, 2002 2:20 am
Good job Jay!
I'm sure they look great!
Had a 99 Solara SE V6. Had a 06 Tacoma. Now I have a 2008 Camry SE V6
Kenn157
Postby Jay » Mon Aug 12, 2002 8:47 am
Well, I just got some better pics, so I thought I would share them with y'all.
Jay
Wiring harness
Postby SKYravefever » Mon Aug 12, 2002 11:20 am
Perhaps getting the wiring harness from suvlights.com would help you with you frying your current wires.
SKYravefever
Postby Jay » Mon Aug 12, 2002 12:03 pm
Just for fun, I am going to make my own.. Heh heh... :)
Jay
sites online
Postby SKYravefever » Mon Aug 12, 2002 6:35 pm
Shouldn't be dreadfully difficult since you're up for the challenge. :D There are plenty of sites that show you how to make it, as you may have already known. I posted a question for you on TN.
SKYravefever
Postby Peter » Mon Aug 12, 2002 8:52 pm
nice pictures on the second set. congrats on the conversion.
Peter's "Black Sheep"
Visit Black Sheep
Peter
