SolaraGuy.com • View topic - DIY on Installing Foglights...
Postby G_Unit » Wed Dec 10, 2003 5:08 pm
Hello everyone....I tried searching and read all the posts. I was wondering if anyone had a link to a DIY on replacing the foglight bulbs. I bought some silverstars and am anxious to get them installed. Also if anyone has installed them, please let me know if you like them or no. Eventually I want to get yellow fogs and a HID system, but I have to spent all my X-mas funds this year....anyways. Thanks.
G_Unit
Postby WTF?? » Wed Dec 10, 2003 5:42 pm
its pretty simple... no need to jack up car
just go under the front of your car and remove the slash guards or just open up enough so you can stick your hand inside where the fogs are at... twist out the bulb and harness (i think its counter clockwise)... remove the original bulbs and replace with your new ones... be very careful NOT to touch the bulb itself
stick it back in and reverse the process... do the same for the other side
takes about 10-20minutes for both sides depending how handy you are :wink:
Im sure those who are experienced in doing this can do it in shorter time, but Im just saying from a new person's point of view
you can try and just replace one side... turn on your fogs to compare the difference... im sure youll be happy with the upgrade
Good luck!!
Retired... its been fun Image
WTF??
Postby FLASH » Wed Dec 10, 2003 7:01 pm
If you still have the owners manual, Im pretty sure there are directions in there. With cute pictures and such too. However, Solara Nytez's explanation is accurate and should be good enough. You will need to take out a few screws and clips in order to remove the splash guard.
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby G_Unit » Wed Dec 10, 2003 7:42 pm
Thanks guys......appreciate it.
G_Unit
Postby Grazi07 » Thu Dec 11, 2003 11:23 am
I think you'll only need a socket set for the splash guards, but I forget what size attachment. If you take all the screws out, make sure you remember which go where, b/c there are 2 different sizes.
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby Edgar22 » Fri Dec 19, 2003 1:53 am
you should probably get a shop manual on the car... extreeeeemely helpful.
1996 Mazda MX-6 V6 MTX... Looking to buy a 1999 Toyota Solara SE V6 MTX.
Edgar22
Postby Mole » Fri Dec 19, 2003 2:29 am
big dude like me needs a jack... damn you thin ppl!
i bet you can retrieve dropped screws with ease in the engine bay too.
