SolaraGuy.com • View topic - New Light bar
New Light bar
New Light bar
Postby Grazi07 » Sun Dec 21, 2003 11:30 am
I want to put a 7" neon tube in my trunk instead of the stock lights, just for better visibility... will I need to change the fuse?
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby swimshady906 » Sun Dec 21, 2003 12:38 pm
Like a white neon? Thats not a bad idea, though u will lose that cool circular pattern the stock light projects into the trunk :wink: I doubt you would need to change the fuse though. If it blows change it, if it doesnt then dont. Its not going to hurt anything. Good idea though, take some pics when youre done
02' S2000 Silverstone
swimshady906
Postby Grazi07 » Sun Dec 21, 2003 1:26 pm
Yeah, something simple, I will miss those circles though. I doubt it'll be too drastic a change, just a little extra light.
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby Grazi07 » Sun Dec 21, 2003 1:28 pm
P.S. Does anyone know which fuse goes to the trunk lights? I don't have an owners manual. Thanks.
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby indiglosolara » Sun Dec 21, 2003 2:37 pm
Grazi07 wrote:P.S. Does anyone know which fuse goes to the trunk lights? I don't have an owners manual. Thanks.
ifs you put a neon tube in the trunk you do not need to replace the fuse...
look at my www link. i have a 10" blue neon tube hooked up to my trunk light and its been a little over a yr since i've installed it.. never had any problems... the neons believe it or not draw less power then the actually light bulb....
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Grazi07 » Sun Dec 21, 2003 4:46 pm
cool, thanks Kenny
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby Grazi07 » Mon Dec 22, 2003 7:26 pm
OK, so in an attempt to install this light bar, I think I blew a fuse. Now my trunk light, clock, and dome light is out. Is that a fuse? Which fuse is it?
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby indiglosolara » Mon Dec 22, 2003 7:29 pm
Grazi07 wrote:OK, so in an attempt to install this light bar, I think I blew a fuse. Now my trunk light, clock, and dome light is out. Is that a fuse? Which fuse is it?
Pull out the coin try on thr driver side closest to the door and there is a label.. it will say trunk lid light..
you must have reverse the polar when you did the install you have to be careful with install and make sure the wires are in the correct place...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby nguyenSTX » Fri Jul 16, 2004 9:19 pm
I'm putting in a neon light in my trunk and i can't seem to get it to turn off when the trunk is closed. I tried wireing it directly from the trunk light socket, anyone know exactly how to wire it?
1999 Toyota Solara SE 4 cyl 5s-fe Auto
nguyenSTX
Postby Grazi07 » Sun Jul 18, 2004 7:19 am
wow, this is an old thread! Props for using the search function! I'll take a look at mine for you, but I don't think I've been having that problem.
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
