SolaraGuy.com • View topic - Transponder Key
Transponder Key
Transponder Key
Postby mycrobyte » Mon Dec 29, 2003 8:32 pm
Hey, the search function does work. And so did the programing instructions. Rock on! Did it in the parking lot while the dealer :bad-words: cried inside about their lost $55 in revenue.
:drinking:
2000 V6 SE
mycrobyte
Postby Yanks0114 » Mon Dec 29, 2003 8:36 pm
Glad to hear that :D
Did you program a new key or remote?
key
Postby mycrobyte » Tue Dec 30, 2003 5:19 am
programmed a key.
They wanted $45 for the key and $55 for the programming. I talked to the manager and got the key for $34 since I bought the car there.
2000 V6 SE
mycrobyte
Re: key
Postby krook » Tue Dec 30, 2003 3:58 pm
mycrobyte wrote:programmed a key.
silly dealerships. tricks are for kids.
krook
Postby adam2562 » Wed Dec 31, 2003 11:24 am
do u mind putting a link for the post where u learned how to program the key please?
Adam - 99 V6 5spd 165k -SOLD
adam2562
Too lazy to search? Ok...
Postby mycrobyte » Wed Dec 31, 2003 9:44 pm
Ok, just don't give me a hard time if I post some noob question in the future.
This worked for my 2000 Solara:
Simultaneously depress and release brake ans accelerator pedals 1 time. Insert original master key into ignition lock.
Depress and release accelerator pedal 5 times.
Depress and release brake pedal 6 times.
Remove original master key from ignition. Insert new duplicate key into ignition lock.
Depress and release accelerator pedal 1 time.
After 60 seconds, security indicator light will turn off indicating new key is programmed.
Remove new key, press brake pedal once to complete registration mode.
It took me a couple tries to get it to work, but it did.
:drinking:
2000 V6 SE
mycrobyte
Postby Mudd » Wed Dec 31, 2003 11:47 pm
Anyone done a remote starter system in one of these cars? I'm assuming that it'll need a copy of the key and an interface module to work properly?
Mudd
Postby Yanks0114 » Thu Jan 01, 2004 1:54 pm
Mudd wrote:Anyone done a remote starter system in one of these cars? I'm assuming that it'll need a copy of the key and an interface module to work properly?
Yes you'll need the bypass module.
Postby offthahook » Fri Jan 02, 2004 1:20 am
Good lookin' out!! Anyone got the sequence for the remotes??? Here's a little more specific sequence for the key itself...
To Program An Additional Key:
1) Place an already programmed Master key (one that works all locks) in the ignition, but DO NOT turn on.
2) Press the GAS pedal five (5) times.
3) Press the BRAKE pedal six (6) times.
4) Remove the key from the ignition.
5) Insert the new key, but DO NOT turn it on.
6) Press the GAS pedal one (1) time only and wait about a minute for the security light to quit flashing.
7) Remove the key and Press the BRAKE pedal one (1) time only.
8) Wait at least ten (10) seconds, then re-insert the new key and start the car.
You can have a maximum of ten (10) transponder keys programmed into your car.
offthahook
Postby adam2562 » Fri Jan 02, 2004 9:57 am
THANK YOU BOTH
adam2562
Postby offthahook » Fri Jan 02, 2004 11:26 pm
Can someone please hook up the sequence for the remote fobs??
offthahook
Postby Mudd » Sat Jan 03, 2004 9:00 am
Sure.
Step 1) Take Remote
Step 2) Put them in your BBQ grill
Step 3) Make burgers! (mmm, burgers)
Step 4) Go to Best Buy and get a real alarm installed.
:D
Sorry, but I find factory alarms and keyless systems to be useless.
offthahook wrote:Can someone please hook up the sequence for the remote fobs??
Mudd
Postby offthahook » Sat Jan 03, 2004 10:13 am
Mudd wrote:Sure.
Step 1) Take Remote
:D
Agreed, but if you take your car to Best Buy for an alarm you might be rolling the dice. They employ high school kids (to save money) who don't care if they mess something up.
offthahook
