SolaraGuy.com • View topic - timing belt
timing belt
timing belt
Postby jetfixer01 » Wed Dec 31, 2003 6:42 am
Has anyone here changed their own timing belt on a 1mzfe? My 99 is at 79k miles and I'll be changing it soon. What I can't figure out is why does the book want you to remove the camshaft timing gears after you remove the belt? Am I missing something here?
jetfixer01
Postby Mole » Wed Dec 31, 2003 8:44 am
kudos to you dude...
i dont think anyone on this board has changed their belt on their own...
i can ask for you thought..
Postby kondo » Wed Dec 31, 2003 3:05 pm
I need to change mine I have about 74K. I know that if I take it somewhere they are going to try and charge me a shitload because of my SC. Figure out how to change it and let us know how it goes.
kondo
SolaraGuy StickerGuy
Postby Mudd » Wed Dec 31, 2003 11:51 pm
There's no reason to touch the cam gears when doing a timing belt. I'd assume it to be a fairly straightforward ordeal. Replace all the belts and tensioners (I'd do whatever seals I could get at when I was in there if I were you), line up the timing marks, and you're ready to rumble. I'd get a factory service manual (yah, bitch bitch bitch I know they're expensive, no excuse not to have one if you're working on your own car though) and use that for reference. I don't find anything online, but I haven't looked much. Maybe one of the Camry forums or websites will have some kind of instructions for this?
Mudd
Postby boneezy » Thu Jan 01, 2004 2:55 am
check the DIY section.. it should be in there...
1999 SE-V6 5spd
160,xxx miles
boneezy
timing belt
Postby jetfixer01 » Fri Jan 02, 2004 6:11 am
I have the service manuals and thats where the procedure calls for removing the cam gears, but I can see no reason why. I've ordered a "timing belt kit" from Toyota that includes the belt, idlers, and tensioner. I'll post back here after I do it, but it will probably be a couple of weeks before I can do the job.
jetfixer01
Postby kondo » Fri Jan 02, 2004 11:59 am
If you have a digital camera try to take a few pics as you go along and are doing it.
Nick
kondo
