SolaraGuy.com • View topic - Stock Iridium Spark Plugs?
Postby xyntax » Sat Jan 03, 2004 5:23 pm
I read on my manual that the 2AZFE engine has Iridium spark plugs installed and 1MZFE has Platinum and that in replacing the spark plugs, we should abide to what was stock. Is there any reason for this variation at all?
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
Postby Turbosolara » Sat Jan 03, 2004 5:45 pm
Maybe because the 2AZFE has higher compression? i think they will use iridium to replace platimum in the future, to get better mpg and performance
Postby Hsakuragi » Sat Jan 03, 2004 7:16 pm
From what i remember is that 02-03's engines are using Iridium plugs, no matter it's at 4 or 6.
Maybe it;s the reason why the IK22 won't fit on my car?
Hsakuragi
Postby Yanks0114 » Sat Jan 03, 2004 10:30 pm
UltraslowSolara wrote:Maybe because the 2AZFE has higher compression? i think they will use iridium to replace platimum in the future, to get better mpg and performance
I'm pretty sure the 1mz has higher compression.
1MZ = 10.5:1
2AZ=9.6:1
Postby xyntax » Sun Jan 04, 2004 8:46 pm
I read online that most new cars will come with Iridium spark plugs installed because it offers better efficiency. It also cools faster than any other type, so it prevents premature ignition and stuff. There are lots of advantages on it. Just check it out at HowStuffWorks.com
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
Postby pro956 » Tue Mar 30, 2004 9:00 am
hsakuragi wrote:From what i remember is that 02-03's engines are using Iridium plugs, no matter it's at 4 or 6.
ik22's won't fit on 03s???
with they fit on 02s?
lmk, i was about to buy em
AIM: pro956
2002 5-speed se v6
pro956
Postby impactX » Tue Mar 30, 2004 9:23 am
Plugs don't add performance.
If anything, copper plugs are the best since you change them often and you'd restore the "lost" power more often.
People use Iridium plugs because it may be hard to change the plugs on their applications and Iridium plugs would buy them some more time before they need to change the plugs.
impactX
Postby Hsakuragi » Tue Mar 30, 2004 9:44 am
Well that mechanic told me the plugs won't fit while he was installing supercharger and it was at the dealer. I was suprised becasue most of the people here said it's going to be fit. But actually it's NOT.
I think Toyota DID made minor changes on the engine for the 1.5.
Hsakuragi
Postby pro956 » Tue Mar 30, 2004 9:57 am
thanks,
any other opinions on this?
i'm about to have my supercharger installed (after 10 million years)
i got ngk blue plug wires, i was going to get denso ik22s
i was under the impression that i should do that, as they burn cooler etc etc
i have a manual 02 solara 3.0L
AIM: pro956
2002 5-speed se v6
pro956
Postby Hsakuragi » Tue Mar 30, 2004 10:49 am
i think the wires will do fine, where u going to get the charger install? well u can get the plugs from autozone, test does it fits or not, if not, you can always return them for store credit.
Hsakuragi
Postby thealkimo » Tue Mar 30, 2004 11:14 am
I recently switched to NGK Iridium IX's, and I haven't noticed any performance gains...but I seem to idle smoother than before. For any performance gains out of the ignition systems I believe installing Magnecor or Nology ignition wires provide the most.
thealkimo
Postby Fletch » Tue Mar 30, 2004 7:01 pm
impactX Posted: Tue Mar 30, 2004 8:23 am Post subject:
I agree. My roommate showed me some threads on VWVortex forum about the HP claims of different plug manufacturers. They had some dyno charts from before and after plugs were changed after the recommended interval and there was no increase in power.
I have a feeling the plug manufacturers get their HP #'s from replacing a totally worn out, inneffective plug with a new one of theirs, then there might be an increase in power.
I don't think the OEM recommendation or Denso Iridiums will make and noticable difference, but get new plugs before you toss a S/C on because once it's on, you can't get to the rear bank.
2006 Legacy GT spec.B
Fletch
Postby pro956 » Tue Mar 30, 2004 9:46 pm
Fletch wrote:I don't think the OEM recommendation or Denso Iridiums will make and noticable difference, but get new plugs before you toss a S/C on because once it's on, you can't get to the rear bank.
i don't even have 10,o00 miles yet
AIM: pro956
2002 5-speed se v6
pro956
Postby xyntax » Tue Mar 30, 2004 11:24 pm
I guess you can only see performance gains if the previous/original plugs were not doing its job properly :roll:
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
Postby pro956 » Wed Mar 31, 2004 9:50 am
xyntax wrote:I guess you can only see performance gains if the previous/original plugs were not doing its job properly :roll:
okay, i was just under the impression that you should get better spark plugs when you add on a supercharger
i think i'm going to just stick with the stock plugs then and just change the wires b/c i already got em-- only 40 bucks anyway
AIM: pro956
2002 5-speed se v6
pro956
