SolaraGuy.com • View topic - Adhesive?
Adhesive?
Adhesive?
Postby Akfahad » Sun Jan 11, 2004 12:00 am
i need to secure my "brain," that connects to my headunit, under my seat. i was thinking of some double sided tape or double sided velcro so i could take it off if i needed to. you guys any better suggestions? also, do you think the tape would melt from the heat generated?
Postby Mole » Sun Jan 11, 2004 12:38 am
doesnt your brain come with a mount kit?
it will be more secure than tape or velcro... but if it didnt, then go for velcro.
Postby HKSV6SLE » Sun Jan 11, 2004 4:54 am
if you use velcro use the industrial grade stuff much stickeir then the noirmal one.
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby indiglosolara » Sun Jan 11, 2004 2:34 pm
i used a piece of wood about the size of the brain and about 3/4 inch thick.. i wraped the piece of wood with th carpet for my sub boxes and mounted the brian to that. worked out great and never had problems with it..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby cruze105 » Sun Jan 11, 2004 3:32 pm
if your putting it under the seat, you can drill the brain to the the floor, thats the way i had it set up.
cruze105
SolaraGuy JerseyMan
SolaraGuy JerseyMan
