SolaraGuy.com • View topic - Fog lights with high beams
Postby aleath » Thu Aug 08, 2002 8:36 pm
What kind of wiring change would be needed to get the fog lights to stay on when the high beams are turned on? Has anyone changed the wiring to do this?
02 Solara SE V6
aleath
Postby Flipside909 » Fri Aug 09, 2002 2:28 am
Unless you can seperate the Fog relay from the headlight relay...you can't change it. It's a safety feature for oncoming drivers to prevent you from blinding their vision.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Jai_Jai_Binks » Mon Aug 12, 2002 3:25 pm
I don't know if any of you watched that Mtv special on street racing. Anyhow, when the cop caught the acura integra guy racing...in addition to racing, he gave him citations for:
1. lowering his car (his was 18', OEM std is 22' - from the bottom to the lights)
2. Non legal lights.....(i'm sure hyper blues)
3. Intake
4. Fog Lights....
Apparently, his fog's didn't go off, when the high beams are on! So be careful. I have respect for law enforcement, only when i don't is when these stupid rules are STRICTLY enforced!....
Postby Missay » Mon Aug 12, 2002 7:52 pm
jhbhatia wrote:I don't know if any of you watched that Mtv special on street racing. Anyhow, when the cop caught the acura integra guy racing...in addition to racing, he gave him citations for:
3. Intake
4. Fog Lights....
I'm ashamed to admit that I actually saw the special. I can't believe that they did that to that girl! I don't race and it definitely scared me from ever wanting to
is lowering the car illegal all together?? I've never heard of that being a violation
Melissa
Missay
SolaraGuy Ambassador
Fog lights on with highbeams
Postby asantoro » Tue Jul 22, 2003 8:10 am
1) Fog light relay on drivers side, left side just above kick panel.
With lowbeams on, turn fog lights on/off, will hear relay click.
2) Remove relay, will see two sets of prongs, one set thicker than other.
Thick prongs are fog power, thin prongs are fog control circuit.
3) Using a digital multimeter, test fog relay receptical.
Find the power lead for fog power (thick prongs) allways on.
Turn fogs on, find power lead for fog control (thin prongs)
4) On relay you removed, bend thin prong so does not go into receptical and using jumper wire, connect to power lead for fog (thick)
Wrap wire around base of this prong so can insert into receptical.
5) Fog lights will now work with both high/low beams.
Note: The reason the the fog lights do not allways stay on even though you jumped it to a constant power supply is that the fog control circuit (thin prongs) only has ground if the headlights are on.
asantoro
Postby Grazi07 » Tue Jul 22, 2003 9:11 am
first off, what they did to that girl on the special was borderline hilarious. Now, I'm not totally cruel, i did feel bad, but it was still funny... anyways, the law, as I understand it, is that your lights have to be at least 22" above the ground. I forget if thats to the center of the light, or the base, but the magic number is 22". You can lower cars, as long as you meet that minimum. Dropping a solara an inch or even two won't hurt
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby Fletch » Tue Jul 22, 2003 10:14 am
asantoro:
Does your described method allow one to run the fogs with the parking lights? If not, does anybody know how besides hardwiring them to the battery with a switch and relay.
2006 Legacy GT spec.B
Fletch
Postby Jai_Jai_Binks » Tue Jul 22, 2003 10:34 am
Fletch wrote:asantoro:
I've done this swap to my celica...(on OEM fog's...just like solara, they run of headlights and not on parking lights)...here's instructions on a celica...
http://www.toyotacelicaonline.com/fogs.htm
does it allow one to run the fogs with the parking lights on
Postby asantoro » Wed Jul 23, 2003 6:02 am
No, it does not.
I am currently researching a way to do this without creating a new circuit.
asantoro
Re: does it allow one to run the fogs with the parking light
Postby Guest » Wed Jul 23, 2003 11:24 am
asantoro wrote:No, it does not.
your thin prong wire is the control? and you hooked it up to the power source (thick prong) for your fogs? does that mean they can be turned on at anytime?
if i am understanding you correctly, take the thin prong wire, and tap it into your parking light wire, then your fogs will only come on when your parking lights are on (including headlights and highbeams).
Guest
fog lights
Postby asantoro » Thu Jul 24, 2003 7:09 am
1) The large prongs are the power circuit for the fogs.
One of these large prong recepticals (where relay plugs in) has constant power. Confirm this with digital multimeter.
2) The small prongs are the control circuit for the fogs.
One of the small prongs has power when low beams are on and fog switch is on. Confirm with digital mutimeter. This is the one you bend and jump to the large prong constant power.
The other small prong has ground ONLY IF HEADLIGHTS ARE ON.
Therefore, your headlights must be on. (RATS!)
If this had ground at all times, you could turn on your fogs on anytime!
If you could intercept this ground after the foglight switch, and gound it to the chassis, you could turn on fog lights anytime.
asantoro
fog lights
Postby asantoro » Thu Jul 24, 2003 7:14 am
Sorry, a small correction.
One of the small prongs has power when low beams are on.
(fog switch does not have to be on, since switch is in grounding curcuit). Confirm with digital mutimeter. This is the one you bend and jump to the large prong constant power
asantoro
