SolaraGuy.com • View topic - engine lights come on and stay on.
Postby tnn79 » Thu Jan 29, 2004 2:52 pm
this happen last wk. i check the gas cap, transmission oil, brake oil, change my oil evey 3k miles, and im not sure what the problem is> any help or suggestion..
99 sle with 85xxxx miles..thanks
tnn79
Postby MGLax13 » Thu Jan 29, 2004 5:14 pm
It's amazing how that light comes on and people come here and ask what it could be. It could be like one of 800 things! If you read the manual, it says check the gas cap, since you did that, if you read further on in the manual, it says that if it isn't the cap to get the car checked out. There si your answer right there. Sorry to be a dick about this but this question comes up every week.
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby DavPak » Fri Jan 30, 2004 4:16 pm
more info please:
when did the light come on, how many miles have you driven since you checked the gas cap.
'02 Solara S/C'ed V6 5-spd
DavPak
reply to mglx
Postby tnn79 » Fri Jan 30, 2004 4:48 pm
you are being a flippin dick head. a whole flippin paragraph you typed,bascially telling me to take it to the dealership! im not that stupid. the whole pt of me posting on here is hoping someone might find out an easy fix for this! otherwise, if dont have anything to say, then just stfu!
and by the way, the gas cap was check right then and there! thanks for the reply!
tnn79
Postby geminimouse » Fri Jan 30, 2004 5:42 pm
...u should watch ur language...people here are only tryin to help, no need to get all pissed off.
The engine light comes on because of numerous reasons. The best way to know what the problem is, is to take it somewhere to get the odbii code. There is no easy fix unless u know urself what the problem is.
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby Coconut » Fri Jan 30, 2004 8:09 pm
Take your car to Autozone, they will check it out for you for free. It's more probably that the oxygen sensor needs to be replaced. Mine has come on on 40K miles and ever since I have not fixed it.
Coconut
Re: reply to mglx
Postby Yanks0114 » Fri Jan 30, 2004 11:28 pm
tnn79 wrote:you are being a flippin dick head. a whole flippin paragraph you typed,bascially telling me to take it to the dealership! im not that stupid. the whole pt of me posting on here is hoping someone might find out an easy fix for this! otherwise, if dont have anything to say, then just stfu!
You're the f*cking idiot for thinking anyone should help you after you talked like this.
If you don't post more specific details then no one can help you.
Postby MGLax13 » Sat Jan 31, 2004 2:00 am
First off chief, I said I was sorry for being a dick, but it's liek coming onto this board and saying "My car doesn't sound right, it's black and has 25,000 miles...what is it?" No one knows, now if you're more specific witht he problem, people might be able to help. Check engine lights come on and almost never does the car start to react in a noticable way so the only way to get your problem fixed is to take it to the dealer. My light came on and it was like some kind of hose fitting that came loose...who would have ever known.
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby Mudd » Sat Jan 31, 2004 9:10 am
An old addage to live by. RTFM. Stands for READ THE F&%'N MANUAL. There's a search engine that works fine, thanks, and everyone that owns a car needs to own a factory service manual (mine will be here on Monday, I bought my car last Thursday). Put forth some effort, and you will be rewarded. Ask stupid questions, and you will be treated as a stupid person.
Mudd
Postby Turbosolara » Sat Jan 31, 2004 8:17 pm
anything wierd will trigger the check engine light on. no matter what you need to have OBDII scanner to get the error code and fix the problem. you can either spend $150 to buy the scanner or pay $50 to dealer or mechanics to scan it for you. Thats the ONLY way to find out what is it.
please no more uneducated talking thanks.
Re: reply to mglx
Postby GR » Sun Feb 01, 2004 1:21 am
tnn79 wrote: hoping someone might find out an easy fix for this!
What happens if a mechanic deferred?
Will it dry up
like a raisin in the sun?
Or fester like a sore--
And then run?
Will it stink like rotten meat?
Or crust and sugar over--
like a syrupy sweet?
Maybe it would sag
like a heavy load.
Or will it explode?
GR
Postby kubi » Sun Feb 01, 2004 2:00 pm
Ya except all you really have to do is disconnect the battery cable, the rest of it doesn't apply.
Please stop humping my car, owner privilege!
kubi
Postby impactX » Sun Feb 01, 2004 2:39 pm
There's no way you can solve this over a forum, go and get the code pulled and you will know right away. MGLax13 was right.
impactX
Postby krook » Mon Feb 02, 2004 4:45 pm
MGLax13 wrote:It's amazing how that light comes on and people come here and ask what it could be. It could be like one of 800 things! If you read the manual, it says check the gas cap, since you did that, if you read further on in the manual, it says that if it isn't the cap to get the car checked out. There si your answer right there. Sorry to be a dick about this but this question comes up every week.
true MGLax13 could've been more polite. i think he's just experiencing that low tolerance level we all experience at some point or another while on the boards. i, too, have looked at a post and said to myself, "what is this flippin' idiot posting!?!" *cough* *cough*superpenis*cough* *cough*
but on the same token, you DO have to be more clear on any other specifics that happened before you CEL came on.
it's probably just your O2 sensor, mines went out for no reason at around 30K. as mentioned, reset the code by taking the negative off the battery for a minute or so.
krook
Users browsing this forum: Google [Bot] and 32 guests
