SolaraGuy.com • View topic - I've been using the wrong model oil filter!?
Postby krzyray » Tue Feb 24, 2004 10:29 pm
I went to Pep Boys today to buy some more oil filters, and I just realized that I've been buying the wrong model oil filter :o
I've been using the Purolator L14476 instead of Purolator L14477.
I could have sworn that I looked in the application booklet, and it said to use the L14476?
Anyways I looked up the specifications at http://www.pureoil.com/
and the only difference between the L14476 and the L14477 is the height.
Anti-Drain Back Valve: Yes
Height: 3.52 for L14477
Height: 2.93 for L14476
Type of Filter: Spin-on
Threads: 3/4-16
Thread Pitch: UNF-2B
Relief Valve P.S.I.: 14-18
O.D.: 2.69
Is this going to cause my car any damage or problems?
krzyray
Postby dan99solara » Tue Feb 24, 2004 11:00 pm
No matter what the book says for your car, if a larger filter fits, its better. That means a lot more oil flow, as well as a larger oil cleaning surface. On my acura legend, i used an OEM honda NSX oil filter, which is the same diameter of one for the legend, but it is a lot longer. this greatly improved my oil flow and allowed for less oil breakdown in the long run. even tho i was using a full synthetic.
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
Postby townboy2 » Wed Feb 25, 2004 4:11 am
when i had my 93MR2 Turbo, i was using the wrong filter too.. stupid local toyota dealer gave me the NA... but the car was run fun and no oil leak...
86 RX-7 crashed
94 MX-6 I4 donated it
93 MR2Turbo sold
00 Solara SLE
86 MR2 N/A FREE from a friend... DONATED too
2007 Nissan Altima Hybrid
townboy2
oil filter size
Postby bfl62581 » Wed Feb 25, 2004 7:15 am
You were using a smaller filter then you were supposed to. How many miles do you have on your car? What kind of oil are you using?
This will determine how much extra "gunk" is in your motor. If you changed your motor ever 3,000 miles (even though Toyota now said I could go 6,000 w/ fully synthetic), you will be absolutely fine (or should be)
I would however switch to the appropriate size.
What filters does everyone here use? I am a fan of the Fram UltraGuard.
bfl62581
Postby dan99solara » Wed Feb 25, 2004 2:39 pm
grr. how many threads must there be until people will stop using FRAM. save your engine and use mobil 1 or oem toyota.
dan99solara
Re: oil filter size
Postby DavPak » Thu Feb 26, 2004 7:48 am
bfl62581 wrote:If you changed your motor ever 3,000 miles (even though Toyota now said I could go 6,000 w/ fully synthetic), you will be absolutely fine (or should be)
toyota does not recommend synthetic oil at all.
'02 Solara S/C'ed V6 5-spd
DavPak
Postby adam2562 » Thu Feb 26, 2004 8:18 am
probably the oil-filter u were using was for the 5s-fe :oops:
Adam - 99 V6 5spd 165k -SOLD
adam2562
Re: oil filter size
Postby krzyray » Thu Feb 26, 2004 7:50 pm
I have about 53,000 miles. I have been using Mobil 1 Synthetic since about 10,000 miles. I always change my oil between 3,000-4,000. Yes I will be definitely purchasing the correct oil filter from now on.
bfl62581 wrote:You were using a smaller filter then you were supposed to. How many miles do you have on your car? What kind of oil are you using?
krzyray
Re: oil filter size
Postby krzyray » Thu Feb 26, 2004 7:51 pm
DavPak wrote:toyota does not recommend synthetic oil at all.
Well Toyota is smoking crack then :lol:
krzyray
Postby SolaraT » Fri Feb 27, 2004 4:28 pm
yeah crack is wack! they must be because they offer regular, syn/blend, and full/syn. If that was the case it would also say it in the manual. It only shows the grade they recomend so the type should not matter.
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby Hsakuragi » Fri Mar 12, 2004 12:06 am
if you want to use toyota OEM filter, use the Yzzb5, the original soalra use Yzzb1, these B5 are for seqouia or all v8 i think, I just changed my oil today and use the B5 since i brought a case of filter for the seqouia, same diamater but just an probably 1 inch longer than the b1.
Hsakuragi
^ was for v6 laras...
Hsakuragi
Postby dan99solara » Fri Mar 12, 2004 6:03 am
thanks hsakuragi! so the Yzzb5 is 1inch longer but the same diameter right?
dan99solara
Postby Hsakuragi » Fri Mar 12, 2004 2:27 pm
same size but longer,
i changed the oil last night and drove for an hour to work today, everything is great, FEEL more power..
Hsakuragi
Postby Hsakuragi » Fri Mar 12, 2004 2:29 pm
ok, i'm looking at the ruler...1 inch is too long... 1/2 inch is about right...
Hsakuragi
