SolaraGuy.com • View topic - When do you check the coolant reservoir?
Postby offthahook » Sat Feb 28, 2004 5:37 pm
Getting ready to go to the STL. Should I look at the level of coolant in my reservoir when the car is running temp. (hot) or after it's shut off and cooled down? Obviously, I don't want to over fill it or leave it too low... :oops:
offthahook
Postby impactX » Sun Feb 29, 2004 5:13 am
I think the level is higher when the car is on, but don't quote me on that. :)
impactX
Postby Akui » Sun Feb 29, 2004 9:32 am
The level is higher when the car is on. The little plastic tank asks as an overfill resevoir. When the engine is at normal operating temp (about halfway on the temp gauge) the resevoir should be at the "full" mark.
Akui
