SolaraGuy.com • View topic - TRD rear sway bar installation
Postby Whatever » Thu Mar 04, 2004 10:17 pm
I just got my rear sway bar, and the shop told guy told me that he is going to charge me 40$ for installation........where did you guys get yours installed? Is it hard to install by yourself? (I read the installation paper and it doesn't seems too hard for me, but the problem is that I don't have the jack to lift up my car)
Whatever
Postby geminimouse » Thu Mar 04, 2004 10:47 pm
It's a simple install. If ur car isn't lowered then u might be able to fit under there...
Or just get urself some jack stands
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby Whatever » Fri Mar 05, 2004 12:23 am
geminimouse wrote:It's a simple install. If ur car isn't lowered then u might be able to fit under there...
No my car is not lowered, and I asked the shop, the guy is willing to let me borrow the tool. He said if I can install it by myself then he won't charge me, but if I can't install it by myself he is going to charge me double :drinking:
Whatever
Postby HKSV6SLE » Fri Mar 05, 2004 12:48 am
hey, hey...which shop? pls dont say E.S..........
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby Hsakuragi » Fri Mar 05, 2004 1:02 am
40 is cheap, go for it
Hsakuragi
Postby Whatever » Fri Mar 05, 2004 4:22 am
HKSV6SLE wrote:hey, hey...which shop? pls dont say E.S..........
It's just a small shop around Torrance :roll:
Whatever
Postby mycrobyte » Fri Mar 05, 2004 5:11 am
forty bucks is nothing. I paid a shop 85 simply because it wasn't worth my time to be crawling around underneath my car when it was like ten degrees and snowy out. even the garage got cold and yucky.
plus I wanted to put the ignition kit on the jeep... :drinking:
2000 V6 SE
mycrobyte
Postby indiglosolara » Fri Mar 05, 2004 9:26 am
I got my TRD RSB installed at discount tire in el monte.. They charged me $25.00 for the install.
I would go there if you have the time. But since your in torr. i dont know if its worth the drive. But $40.00 is not that much.. i would go for it and save you the pain of doing it yourself.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Mole » Fri Mar 05, 2004 9:38 am
all you lazy arse fools...
i would and did do it myself.
Postby Jackass-Jeff » Fri Mar 05, 2004 10:29 am
discount tire center charges 20 ...
i dont know if the other shops will do it, but that's the price in el monte... just say you're w/ the other solara people lol
1GR-FE ftw!
Jackass-Jeff
Postby SolaraT » Fri Mar 05, 2004 3:40 pm
What is it like two bolts? I did more work installing my head unit and front and rear speakers. Thats a month worth of gas for me so I would do it myself. :wink:
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby geminimouse » Fri Mar 05, 2004 3:51 pm
4 bolts and 2 nuts.
I'd recommend doin it urself, so it would be easier in the future if you need to relube the bushings or change the setting.
08 Accord Coupe
geminimouse
Postby Whatever » Fri Mar 05, 2004 5:39 pm
cool thanks for the advice, I got it installed for $20. I was there watch him doing everything, so I know what's going on now. I took off two more nuts then you guys, cuz he had to unscrew the pipe in order to take off the original sway bar.
Whatever
Postby HKSV6SLE » Sat Mar 06, 2004 4:54 am
which shop was it?
www.lexusnet.com
HKSV6SLE
