SolaraGuy.com • View topic - Making Moon Roof operable when the car is off?
Postby pythonjosh » Sat Apr 03, 2004 2:59 pm
It seems the Moon Roof is connected to a 'Hot when on (ACC)' wire.
Does anybody know how where connect it to an always hot wire?
Thanks,
Josh
pythonjosh
Postby Mudd » Sat Apr 03, 2004 6:10 pm
It's obviously going to be where the switch is. Pull that down and get in there with a mulitmeter, see what's what. Then run a constant wire from wherever.
I have mine operational with my alarm with a DEI window module. Not that difficult at all, especially when you figure out what wires do what.
Mudd
Postby pythonjosh » Sat Apr 03, 2004 10:55 pm
what voltage / wattage do I need for the new wire? And going another
way, where can I find where it's power comes from (ie under the dash, the ECU, etc) and cut and splice it with an always hot wire? That way I
won't have to figure out how to run a wire under the ceiling carpet up
to the head console. Thanks,
Josh
pythonjosh
