SolaraGuy.com • View topic - putting a piston back into the block
Postby SC V6 » Thu Apr 08, 2004 10:28 am
anyone know how hard it would be to put a piston back into the block? like what tools you would need, and how to go about putting it back in?
thanks
Scott
SC V6
Postby Fletch » Thu Apr 08, 2004 10:36 am
I've only ever helped out on a Ford 5.0 L. You need a piston ring compressor tool.
We also replaced all the main bearing caps. In the end, the car had bad high RPM vibration. It had to be torn apart, put back together by a shop, it was out of balance.
I guess just be real sure you know what you're doing.
2006 Legacy GT spec.B
Fletch
Postby SC V6 » Thu Apr 08, 2004 10:54 am
well its my old block that im putting it back into.. im not going to use it... I just want to get the pistons back in the block while its being stored... because later on I may bore the engine block out, and run forged pistons.. so.. I want to keep it all together till that time...
thanks
Scott
SC V6
Postby dan99solara » Fri Apr 09, 2004 5:24 am
just take off the oil pan, and head, compress the rings, slide the piston and rod down, and bolt it on.
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
