SolaraGuy.com • View topic - headunit dash kit & mp3 player
Postby Turbosolara » Sun May 02, 2004 11:34 pm
Where did you guys buy the headunit dash kit for gen1 solara? I like the one with a storage deck...I would also like to know how much is it and the diffcultness to install it. thanks
also if you guys would share a review for mp3 player, i would highly appreciate!
Joseph
Postby Jackass-Jeff » Sun May 02, 2004 11:58 pm
it's pretty easy to install. just takes some time.
most audio shops will have the "pocket" because most toyotas use the same dbl din size. It should run 10-15$ unless you want the fancy one found in stock accords (w/ the little door) then it's more (if they even make it.)
A good basic mp3 player would be the Eclipse CD 3414. I had that as a temp unit and it was nice. It even corrected some "screachy sounds" found in some mp3s... that amazed me lol. That think retails @ 199 I think. If that's high for your budget, then I don't know what's good in the 100-200 range.
Good luck
1GR-FE ftw!
Jackass-Jeff
Postby Turbosolara » Mon May 03, 2004 12:25 am
thanks for the reply. Eclipse sounds very good to me, i had really good impression about it. But if i remeber right, none of them come with detachable face right?
Postby ZXLNT » Mon May 03, 2004 12:48 am
I think your right on the Eclipse, they dont have detach face. Another good unit is the Clarion DXZ835MP. Around 219 dollars at thezeb.com They had been on sale a while back so I can' guarantee they still have them. I have one in my Solara. Works great, not a hint of trouble with and it does have detachable face..
ZXLNT
Postby Jackass-Jeff » Mon May 03, 2004 8:06 pm
UltraslowSolara wrote:thanks for the reply. Eclipse sounds very good to me, i had really good impression about it. But if i remeber right, none of them come with detachable face right?
no detach. face but if it gets jacked (1 year from first date of use) they replace it for free :P
1GR-FE ftw!
Jackass-Jeff
Postby Turbosolara » Mon May 03, 2004 11:10 pm
The reason i was using my factory headunit because i dont want to attract someone to break the window (and they will find more and more goodie in my car). but now my radio is broken that i cannot listen to any of radio station, so i guess its time to get a head unit. I think a good way for hinding the eclipse unit out is to use the factory cd player face plate to hide it out. (seen done on civic before).
I like clarion because it is very user friendly..but if i remeber in my old clarion, I dont have much freedom to tune the tone isnt (only have pre-set eq....Z-hencer). Does those newer one different?
Postby Jackass-Jeff » Mon May 03, 2004 11:42 pm
i had the clarion 935 dvd screen (I think your friend Jon bought it from me) and the audio settings were still pretty crappy x_X
1GR-FE ftw!
Jackass-Jeff
Postby HKSV6SLE » Tue May 04, 2004 3:35 am
kenwood has a good excelon unit....that has a detachable face....
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby ZXLNT » Tue May 04, 2004 5:22 am
Yes the clarion has tonal adjustment for Bass mid and treble. with frequency adjustment for all three and "q" adjustment for bass and midrange.
ZXLNT
Postby Akfahad » Tue May 04, 2004 7:51 am
i've got the clarion 935 and the face sticks out maybe about an inch from the dash. is everybody's like that or is there a certain kit that you can get to make it flush??
Postby SKYravefever » Tue May 04, 2004 3:37 pm
Alpine has various models to choose from. I've been an avid Alpine fan. Personally, my 9824's been going strong for 2 years.
SKYravefever
Postby SolaraT » Tue May 04, 2004 5:16 pm
You can get the 95 Camry factory pocket that has that little door that is so cool. Otherwise 10bucks for the generic one with the pocket hole.
It depends on what you want to do with your system. I just wanted strong power to my speakers with no external amp and went with Alpine's CDA 9815 model. You can tune it really well and has a Mosfett V-Drive internal amp 60w x 4 (27x4)RMS They actually recommend a 10 gauge power wire directly from the battery. I love it! The thing bumps like crazy! It just took time to tune it since it has crossover, equalizer, & Bassfocus.ect.. You can actually pinpoint sound from each speaker to reach your ears at the same time! Not to mention other stuff I have not even checked out yet.
Pic... http://home.comcast.net/~daddytortora/SolaraInside.JPG
I don't think it's being sold anymore but here is its replacement...
http://www.crutchfield.com/S-undOU25v8o ... =Y&search=
Of coarse you can get it allot cheaper somewhere else. . .
Good luck with your mod! Hey don't worry about theft! Just make sure you get a detachable face (Most are) and it won't draw attention.
Alpines do!
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby Jon11582 » Tue May 04, 2004 6:33 pm
Akfahad wrote:i've got the clarion 935 and the face sticks out maybe about an inch from the dash. is everybody's like that or is there a certain kit that you can get to make it flush??
Most aftermarkets jut out, especially ones with detachable faces, so you can easily take the face off.
Easy way to fix this is drill holes further back on the mounting bracket that comes with the pocket.
Hmm..door with a pocket. I think I might look into that since stuff is flying out of my pocket all the time if I floor it. Where can I find one of these?
2000 Black Solara SE
Jon11582
Postby SolaraT » Wed May 05, 2004 3:09 am
junk yard or toyota dealer. ask for the lower plastic din. It's for a 95 camry. If you get to find out the price let us know.
2007 VW GTI
SolaraT
Postby whiteflash » Wed May 05, 2004 8:37 pm
Actually I just bought the VRX630 im thinking is it a easy install?
Injen w/CAI Extension
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Users browsing this forum: No registered users and 94 guests
