SolaraGuy.com • View topic - Intake System on ebay
Postby Swifty0915 » Tue May 11, 2004 12:40 pm
Hey guys im new on solaraguy....I have a question though, i wanted to get an intake for my 2000 Solara 4cyl, and i saw this one on ebay.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 01599&rd=1
I was wondering if you guys think it would be good one with all the neccessary wiring and everything.
Swifty0915
Postby Jon11582 » Tue May 11, 2004 12:49 pm
From what I hear, these are crap
It doesnt come with all the necessary parts, and itll decrease performance. These old 4cyls are slow enough as it is.
Injen is the only one to consider really, but even that will decrease performance without a cold air intake extension.
2000 Black Solara SE
Jon11582
Postby Astro » Tue May 11, 2004 2:43 pm
I agree with Jon11582, just go for a K&N or TRD drop-in. The short-ram is worthless. They bring in nothing but hot engine air, which in turn decreases power.
Postby SolaraT » Tue May 11, 2004 3:26 pm
Another eBay intake question. Not good. Someone that has one (not going to mention the name :wink: ) was trying to figure out how they heck to put in the sensors correctly. He took pics and sent them to me and turns out it is not designed to fit the sensors correctly. Injen has a flawless setup. Downside is you will loose low end hp with short ram. Get the Injen short ram and custom connect the CAI extension for the V6! (You can find it here using the search) Then you will gain for sure! There is a DIY in the DIY section for installing the extension if you’re interested. Multiple engine diagnosis shows no issues with the CAI set up!!
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby Swifty0915 » Tue May 11, 2004 8:47 pm
Alright thanks guys. Where could i get the Injen short ram and custom CAI from?
Swifty0915
Postby Jon11582 » Tue May 11, 2004 10:16 pm
Its alot more money, and the gains are not that much, esp for a 4cyl. Not worth it in my opinion, unless you just want a little more rumble under the hood.
Jon11582
Postby Astro » Wed May 12, 2004 1:15 am
Check these threads for info:
http://www.zer0.info/solaraguy/viewtopic.php?t=6375&highlight=cai -there's a link where you can buy it, I forgot what page
http://www.zer0.info/solaraguy/viewtopic.php?t=8795&highlight=
-had problems with lining the extension, but found the piece to fix the problem, with finished pics
Hope this helps...Later
Postby SolaraT » Wed May 12, 2004 3:53 am
The CAI is money well spent. IMO
Gains are noticable.
Look around, you got lots of resources on this site.
The sky is the limmit. The install for your application... http://www.zer0.info/solaraguy/viewtopic.php?t=7933
Good Luck!
O and check various online vendors for the Injen short ram. www.injen.com / I got mine from www.adventon.com / The extention can be purchased from Matt...Follow the first link Astro posted...
2007 VW GTI
SolaraT
Postby Swifty0915 » Thu May 13, 2004 8:57 pm
alright thanks alot guys
Swifty0915
Postby MaxBoostSolara » Thu May 13, 2004 10:02 pm
[quote="solarat"]Another eBay intake question. Not good. Someone that has one (not going to mention the name :wink: ) quote]
that's me... yea i bought 1. mine's was from procarparts.com. i thought it helped some.... but thats cuz i took out my fog lights and routed an aluminum pipe to the intake making it a ram air system. I also "tried" to put grill mesh in there to cover up the pipe...
MaxBoostSolara
Postby MaxBoostSolara » Thu May 13, 2004 10:03 pm
by the way... i love the way it sounds so i think it was worth it
MaxBoostSolara
Postby Swifty0915 » Fri May 14, 2004 1:23 pm
Do you think it made any performace improvement? or just for the sound? Did it come with the neccesary parts as well?
Swifty0915
Postby MaxBoostSolara » Sat May 15, 2004 11:54 am
well... it sorta came with the necessary parts. i just didn't know what goes where n where goes what. my intake is "customized" to fit. if you are worried bout the then necessary parts, go w/the injen intake. i cheaped out cuz i didn't really care. any short ram seems to be just as good as any other short ram to me. most of them pull in hot air anyways. unless you build an aluminum shield to where it somewhat blocks the hot air. the KNN typhoon intake comes with 1 but they don't have 1 for our car. even then that pulls hot air. i believe that it improved performance but mainly top end since air is required to be forced to the intake. i didn't feel a difference at all when i first put the intake in but once i put the pipe in, i felt a slight increase in my top end power. i feel stock now cuz i just put 2 12s in my car.
MaxBoostSolara
Postby SolaraT » Sat May 15, 2004 3:47 pm
If you don't have these options then you will have a hard time...
2007 VW GTI
SolaraT
Users browsing this forum: No registered users and 94 guests
