SolaraGuy.com • View topic - od off?
od off?
od off?
Postby 99SEAUTO » Sun May 23, 2004 7:44 pm
is it better to drive with the od off or od on
overdrive?
99SEAUTO
Postby Yanks0114 » Sun May 23, 2004 8:10 pm
od should b on.
Allows you to go into overdrive(4th gear).
better gas mileage and less strain on your engine
Postby krzyray » Sun May 23, 2004 9:32 pm
Yes being in overdrive gives better gas mileage. I use it on the freeway. But if you are on the streets and you like better performance (driving fast), I would turn overdrive off so you are in 3rd gear.
krzyray
Postby 99SEAUTO » Mon May 24, 2004 11:07 am
thanx for the info
99SEAUTO
