SolaraGuy.com • View topic - TRD springs on factory struts?
Postby neo6205 » Mon May 24, 2004 10:55 pm
I'm a newbie here and have a question about my springs/struts. I bought a set of TRD springs off a guy's showcar and installed them. I didn't have enough money to buy new struts so I used the stock struts. After reading some on the forum it sounds like everyone upgraded both springs and struts. Is there a problem only doing springs for now?
neo6205
Postby Jackass-Jeff » Mon May 24, 2004 11:21 pm
this will cause the stock struts to wear a lot faster than they should. eventually you will be bouncing like a beeeeeeeeeeeeeeeeotch! It's ok if you don't mind boucing around, but you'll eventually have to replace the struts due to over-wear.
1GR-FE ftw!
Jackass-Jeff
Postby prowlerartist » Tue May 25, 2004 7:58 am
i have trd springs with stock struts, ive had this setup for about 50,000 miles and still no difference in ride quality. If you are going to toss the the stock struts anyway, might as well leave em on till they go bad.
prowlerartist
Postby HKSV6SLE » Tue May 25, 2004 11:39 am
ive been running trd springs and stock shocks ever since i had 5K on my car...90K later no problems lots of bouncing but otherwise..
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby shidosha01 » Tue May 25, 2004 11:47 am
You will blow your struts. But I've heard from other people that they feel no difference except when they drive over speed bumps.
I had Intrax Springs on my 3rd Gen Camry V6 with stock struts and the ride was really bad.
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Postby SoLaRa_PimPin99 » Wed May 26, 2004 7:39 am
i have eibach springs and i drove with stock stuts for about a year. It rode cool until recently where i would bounce a little too much and my car would bottom out so i would recommend you buying struts as soon as you can!
99 Solara SE V6 Black w/ Blue Pearl (New Paint job)
19" Niche F-16 (215-35-19 Nitto gen's)
Eibach Pro-kit
Tokico Blue Struts
Dual Cat-back Exhaust
Altezza Carbon Fiber tailights
SoLaRa_PimPin99
