SolaraGuy.com • View topic - PCV Valve
PCV Valve
PCV Valve
Postby bassthrive » Tue May 25, 2004 1:22 pm
Im doing some routine 60k maintenance, including replacing the PCV valve on my V6. I was happy to hear it was an easy job after reading some posts about it, but after taking the plastic cover off the top of the engine, I cant find the damn thing! I took some pictures, maybe someone can cure my ignorance.
I've looked all around the top of the engine for something that looks like the new PCV I bought but with no luck.
- Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby SC V6 » Tue May 25, 2004 1:32 pm
its on the back side where the intake manifold is.. take a picture from the Passanger side of the back of the engine and I can point it out
SC V6
PCV Valve
Postby jim@foreignaffairs » Tue May 25, 2004 2:20 pm
The PCV Valve is in the rear valve cover under the S/C on the passenger side. You can't replace it without removing the S/C.
Jim
jim@foreignaffairs
Postby bassthrive » Tue May 25, 2004 3:15 pm
Thanks Scott and Jim!
This thing was a joke to replace. Took me less than a minute from start to finish once I found the little bastard. I forget the post I read that said the engine cover needed to be removed, it definately does not.
Here are some pictures I took after I put the new PCV in - I may post these in the DIY section.
:::EDIT::: A closer look
-Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby krook » Tue May 25, 2004 5:03 pm
too dark. :P
krook
Postby krzyray » Tue May 25, 2004 6:55 pm
I have a 2002 Solara SE (2AZ-FE). Has anybody replaced the PCV valve on this engine?
I posted a thread about it here but no one replied...
http://www.zer0.info/solaraguy/viewtopic.php?t=8332
krzyray
Postby whiteflash » Sun Jun 13, 2004 10:00 pm
i have 58500 should I change mine? what exactly does this do by changing this
Injen w/CAI Extension
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby bassthrive » Mon Jun 14, 2004 10:53 am
PCV = Positive Crankcase Ventilation. This is part of out emissions control system - it uses the engine's natural vacuum to air out the crankcase, pulling the nasty combination of gases that escapes past the piston rings into the intake stream to be burned. Called "blow-by," these gases are a combination of raw fuel, water vapor, oil fumes, and the byproducts of combustion. Not only does this stuff befoul the air we all breathe, it also contributes to the formation of sludge, varnish, and other troublesome deposits inside the engine. It behooves you to replace this $3.68 part.
- Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Jai_Jai_Binks » Mon Jun 14, 2004 12:17 pm
bassthrive wrote:It behooves you to replace this $3.68 part.- Paul
Convinsing vocabularly!
Postby Astro » Tue Jun 15, 2004 9:45 am
bassthrive wrote:Took me less than a minute from start to finish - I may post these in the DIY section.
It sure won't be much for a DIY :D, since it was a >1 min job.
Larry
Postby bassthrive » Tue Jun 15, 2004 10:59 am
Larry
yeah youre right, its the easiest piece of hardware i have ever replaced on a car.
- Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Hsakuragi » Tue Jun 15, 2004 1:06 pm
is it possible to change it without taking the charger off?
Hsakuragi
Postby bassthrive » Tue Jun 15, 2004 7:03 pm
Yeah its possible, but tight. Not nearly as impossible as say, changing your plugs.
- Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
