SolaraGuy.com • View topic - intake problems
intake problems
intake problems
Postby 99SEAUTO » Sat May 29, 2004 10:36 am
Ok, I installed a short ram intake on fri, it was the worse thing ever, first the engine started shakin, i reset the computer so the fuel ratio and all the crap readjusted itself, so then it was fine normal idle.
Than when i hit it off the line it was SOOOO SLow, i actually lost horsepower cuz of that crap, it took more warm air in then ever, put the stock one in, much better, Is this a common problem
99SEAUTO
Postby Astro » Sat May 29, 2004 11:02 am
If you bought one of those Ebay 'specials', then that's your problem. You get what you pay for. Most of those companies never do any R&D on their products. If you want to do it right, get an Injen short-ram and UPFD CAI extension. It's made for the V6, but will work for the I4. If not, a drop-in filter works great.
Larry
UPFD CAI extension
Postby Ferrari_1299 » Sat May 29, 2004 1:48 pm
" UPFD CAI extension"
Wher do you recomend getting one of these?
About how much are they?
Thanks
1999 SE V6
Eibach Springs, Tokicko Struts, CF Hood, Custom Grill, Clear Corners, more to come...
http://www.cardomain.com/memberpage/275185
Ferrari_1299
Re: intake problems
Postby MaxBoostSolara » Sat May 29, 2004 2:17 pm
99SEAUTO wrote:Ok, I installed a short ram intake on fri, it was the worse thing ever, first the engine started shakin, i reset the computer so the fuel ratio and all the crap readjusted itself, so then it was fine normal idle.
this is typical of a short ram so don't worry... it's really supposed to help out more in top end power... laters
MaxBoostSolara
Postby Astro » Sat May 29, 2004 6:23 pm
check this link it will tell you everything:
http://www.zer0.info/solaraguy/viewtopic.php?t=6375&highlight=cai+extension
MaxBoostSolara: I never had that problem with the Injen short ram. You shouldn't get any engine shaking. But, you definately loose low end.
Postby MaxBoostSolara » Sat May 29, 2004 7:14 pm
oops... my bad astro... i didn't mean that i get the shaking too... i was talkin about the low end power loss... guess i should have been more specific.. o well.. too late... laters
MaxBoostSolara
Postby ICrazyChrisI » Sun May 30, 2004 3:39 pm
I'd imagine you'd need to drive it around for a bit before flooring it.
ICrazyChrisI
Postby Keg-Of-Iron » Sun May 30, 2004 11:19 pm
Exactly Chris, I installed a cheap one at first and had to drive around for like 20 minutes before I could push my car hard. But those short rams end up sucking more hot air=bad, so get what Astro is talking about. I installed it and it works great!
FIGHT ON U.S.C.!!!
2000 SE v6 5spd Supercharged! 6 lb. pulley...
http://www.cardomain.com/memberpage/510493
Keg-Of-Iron
Postby DatSRBoi » Mon Jul 12, 2004 11:54 pm
MANN just brought me that ebay ram air too.... So its really that gay???is there any way i can rig it to get it running good? And why is its gay? its just like any other ram air? i got the pipe but have a OBX filter with it.. Or is it because of the part where you plug in the sensor that sucks? please let me know ASAP..I WANT POWER hahaha at cheap that is...
Postby Rudy » Mon Jul 12, 2004 11:59 pm
an intake is not a sexual being.
therefore it can't be gay.
(sorry, pet peeve)
99 Solara V6 5SPD
Rudy
Postby TadS » Tue Jul 13, 2004 8:01 am
Kung Fighting Dude wrote:I hope no problems would occur while driving with the CAI installed in my car.
There shouldn't be any as long as you don't drive into a lake. I don't know if anyone has done a CAI on a 2AZ-FE motor yet though, so keep us posted on what happens :).
TadS
Postby DatSRBoi » Tue Jul 13, 2004 10:15 am
Hmm ok. One more thing. Isnt an intake just an intake? Like the one off of Ebay. I wont use their ghetto intake filter. Im putting an OBX on it which is good, but isnt the pipe just like any other pipe? I really dont get it. Always thuoght that its just the intake filter that matters, not the pipe unless its turning the intake filter against the engines heat. Other then that arnt they all the same?
Postby 808Camry » Tue Jul 13, 2004 11:49 am
The gains are minimal if any. As far as your shaking, it could be a loose hose, or car needs to adjust. Power loss, if you only increase the air coming in, and don't open up the hole it comes out of you won't get much in terms of performance. It's more of a cosmetic mod and nice noise maker.
808Camry
Postby DatSRBoi » Tue Jul 13, 2004 1:30 pm
So you saying its not the pipe off ebay that is bad? And that it might be becuase its only intake and no output to put it too yet? if so then its time to hit up a exhuast haha..thanks homie..hope it works
