SolaraGuy.com • View topic - Stereo and AC reset everytime I start the car
Postby Poman » Thu Jun 03, 2004 5:32 am
Everytime I start the card I have to re-enter the code for the MP3 player. My AC is reset back to default setting. But my clock is not resetted. The battery is pretty new, replaced within a year. Is my alternator or starter is going bad? Help! Thanks!
Poman
Postby Jackass-Jeff » Thu Jun 03, 2004 7:59 am
bad headunit installation'
he probably tapped the wrong a/c power cable
One is supposed to be connected to a constant supply so it knows it's still connect to the car... or something like that
1GR-FE ftw!
Jackass-Jeff
Postby whiteflash » Thu Jun 03, 2004 9:27 am
YEA rewire the plug somethine with constant power
Injen w/CAI Extension
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby groovespacer » Thu Jun 03, 2004 11:52 am
I hope you bought a harness rather than hacking wires. Using a harness will lower your chances of making a mistake too.
groovespacer
Postby Grazi07 » Thu Jun 03, 2004 3:10 pm
You can also just hardwire to your battery, I did that with mine....
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby Poman » Thu Jun 03, 2004 6:02 pm
It was working fine for the longest time for about 2 years. It resets everytime I start the car. If I don't start the car everything works fine. The receiver works fine as soon as the car starts but I have to set the damn passcode. Weird. Looks like to me that when the car starts, somehow the alternator lost power between the transition from battery over to alternator when the car starts?
Poman
Postby Mudd » Sat Jun 05, 2004 7:42 am
Check your fuses.
Mudd
Postby Yanks0114 » Sat Jun 05, 2004 5:50 pm
Mudd wrote:Check your fuses.
Most likely its not a fuse if you are still getting power. Unless you have an inline fuse on the constant 12 volt, it shouldn't be affected
You might have a short. Take a multimeter and make sure that the red wire (ignition) going to the headunit only has power wtih the car on and hte yellow wire (constant has it all the time
