SolaraGuy.com • View topic - changed battery, cold start is odd
Postby krazeee1707 » Thu Jun 03, 2004 3:45 pm
My battery died last week and I had to replace it. The next morning, my car was acting funny. In the past, when I started up the car in the morning, it would rev up to 1500-2000. Now, when I start the car for the first time in the morning, it only revs up to 1000. I reset the Ecu already and its still doing this. The car is running different also, it just doesn't feel the same (maybe its in my head). It idles perfectly fine, but feels like its struggling. Anyone have this problem before? Do I have anything to worry about? Info and solution is appreciated Thanks..
LOU
krazeee1707
Postby Mole » Thu Jun 03, 2004 9:37 pm
when you reset the ecu, did you let the car idle?
check your air filter, maybe something is clogged.
you might want to re-reset the ecu again.
Postby eecc » Thu Jun 03, 2004 9:49 pm
maybe u should give it week or so, resetting the ecu causes it to relearn everything again, like adjusting timing ur driving habits etc.
eecc
Postby Mole » Thu Jun 03, 2004 9:56 pm
eecc wrote:maybe u should give it week or so, resetting the ecu causes it to relearn everything again, like adjusting timing ur driving habits etc.
it only takes 10 mins at most for the ecu to re-map everything.
Postby Jackass-Jeff » Thu Jun 03, 2004 10:47 pm
4 (or 6? i forgot what they said) gas tanks, according to our ASMs
1GR-FE ftw!
Jackass-Jeff
Postby bassthrive » Fri Jun 04, 2004 12:45 am
By rev do you mean idle speed? That sounds high for idle. After cleaning my air filter and battery (coincidentally resetting the ecu) my V6 idle levels out at a buttery smooth 500 rpm.
- Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby krazeee1707 » Fri Jun 04, 2004 4:53 am
bassthrive wrote:By rev do you mean idle speed? That sounds high for idle. After cleaning my air filter and battery (coincidentally resetting the ecu) my V6 idle levels out at a buttery smooth 500 rpm.
- Paul
Not idle...i meant how high it revs when I first warm up the car first thing in the morning. When it warms up, the idle is actually fine, but the car still doesn't feel right.
krazeee1707
Postby krazeee1707 » Fri Jun 04, 2004 4:54 am
The Bogey Man wrote:when you reset the ecu, did you let the car idle?
Thanks, I don't think i let it idle that long when I reset ecu again. I'll check my filter. Hopefully thats what I did wrong, this never happened to me in any of my cars, so I'm getting kind of worried.
krazeee1707
