SolaraGuy.com • View topic - check engine light
check engine light
check engine light
Postby Loungin1121 » Fri Jun 04, 2004 3:59 pm
on my 99 v6, its happened twice already, my check engine light comes on the day after i get gas. there's nothing wrong with the car or engine, so i bought a new gas cap, thinking it was the gas cap screwing up the comp, but it still came on...its come on the day after i get gas and then lasts for 2-3 days and just goes away? what do you guys think?
i don't know what i'm doing, i just make it up as i go
Loungin1121
Postby sunrise_solara » Fri Jun 04, 2004 6:36 pm
Did you go back with a Toyota gas cap or an aftermarket? My mom had the same problem in her Camry, along with a lingering gas smell and turns out, the cap was replaced somewhere along the line with a Walmart cheapo...Only advice I can offer, so I hope this helps...
David
sunrise_solara
Postby Turbosolara » Fri Jun 04, 2004 7:12 pm
you need to scan for the trouble code, because there are million of factors might trigger the light.
Postby MGLax13 » Fri Jun 04, 2004 8:21 pm
It might be crappy gas if it's right after you get gas. THat happened to me a few times. There was water in the gas. I just had to buy a bottl eof dry gas and that fixed it right up.
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
check engine light
Postby Loungin1121 » Sat Jun 05, 2004 12:12 pm
so getting the code, can i do that on my own, or do i have go to a dealer...i remember hearing about u need to have a special diagnostics checker for toyotas?
Loungin1121
Postby Grazi07 » Sat Jun 05, 2004 12:23 pm
yeah, you need to go to either a dealer of a gas station with an OBD-II reader. Costs about $75 to have it read, and takes about an hour....
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby Turbosolara » Sat Jun 05, 2004 2:18 pm
you can just buy the OBDII scanner for about 60-200 dollars. do it by yourself take only 2 minutes to read the code and shut the light off
Postby Stock Solara SEV6 » Mon Jun 07, 2004 8:44 am
AutoZone was advertising on the radio they would pull the CE codes for you for free, at least in the Chicago area.
2001 V6 5-speed
Stock Solara SEV6
Postby bkp_duke » Mon Jun 07, 2004 8:50 am
yeah, i've the the CE light on twice and autozone read the codes for free for me both times (NC area)
one was the EGR valve, other was a blown O2 sensor
bkp_duke
Postby Loungin1121 » Mon Jun 07, 2004 9:01 am
autozone it is. thanks guys
Loungin1121
Users browsing this forum: Google [Bot] and 9 guests
