SolaraGuy.com • View topic - Anyone know what this means?
Postby cruze105 » Mon Jun 07, 2004 9:57 pm
the little icon all the way to the left that show a pic of a car with lights coming out, any one know what this means, i check my lights, they work fine.
it only goes on once i go into gear.
any one know?
cruze105
SolaraGuy JerseyMan
SolaraGuy JerseyMan
Postby i20solara02i » Mon Jun 07, 2004 10:28 pm
one of your light burned out
i20solara02i
Postby thealkimo » Tue Jun 08, 2004 1:09 am
it appears when there's a brake light failure and only appears after you hit the brake...mine's always on because i have an aftermarket OEM style spoiler that has the wrong output on the LED brake light
thealkimo
Postby Jai_Jai_Binks » Tue Jun 08, 2004 7:10 am
have someone de-press the brakes while you go and check to see which one of the bulb(s) is exactly out...Its kinda hard to do both things at the same time... :fadein:
Postby xsolara33x » Tue Jun 08, 2004 8:12 am
one of your taillights burned out... happened to me a while ago... press on your brakes and let someone else look to see which one is out...
xsolara33x
Postby V8killa » Tue Jun 08, 2004 8:43 am
Rear Tail light out, just went through it. I love that it tells you though.
95 auto Corolla w/turbocharged 20V Motor
97 Camrey XLE V6----GONE I Miss her so much
99 Solara SLE V6 UNDER CONSTRUCTION
V8killa
Postby Jai_Jai_Binks » Tue Jun 08, 2004 9:13 am
V8killa wrote:Rear Tail light out, just went through it. I love that it tells you though.
All1990+ toyota's do that..i know my dad's 1990 cressida wagon did that as well...my 1990 celica did that...
Postby Jon11582 » Tue Jun 08, 2004 9:42 am
Its the rear brake light failure indicator. Mines also on all the time, since I pulled out my third brake light when I put my spoiler on. I just yanked the brake indicator bulb, since I cant fix it without rewiring the spoiler light. To check all the states, put your parking lights on, flick the hazards, and have someone step and get off on the brake. Might be something loose if it only happens when you go in gear.
If u need a hand on checking it out, feel free to gimme a call or PM me.
2000 Black Solara SE
Jon11582
Postby Ford_Fixorrepairdaily » Tue Jun 08, 2004 10:27 am
im pretty sure its the light blub. same thing happen to me. i think the reason why the light still turns is becuase it has two filaments? one side is burnt it the other is not and it appears to be on, but when you step on the brakes it goes out. just change the blub its only like 3 bones at kregans or something.
Postby geminimouse » Tue Jun 08, 2004 3:22 pm
if it happens when u shift into reverse then it's ur reverse lights.
push on the brakes and it comes on then it's ur brake lights.
etc. etc.
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby cruze105 » Tue Jun 08, 2004 8:38 pm
thanks guyz i found out it was my driver side brake light, i guess the first time i checked i didnt check so good.
cruze105
SolaraGuy JerseyMan
SolaraGuy JerseyMan
