SolaraGuy.com • View topic - Third gear
Third gear
Third gear
Postby whiteflash » Sat Jun 12, 2004 10:15 pm
hey anyone else synchros going in third gear?
Injen w/CAI Extension
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby boneezy » Sat Jun 12, 2004 11:38 pm
mine is 2nd
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby whiteflash » Sun Jun 13, 2004 9:14 am
some place said i cant get one synchro replaced i have to get all of them done and its gonna cost a grand
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby Jai_Jai_Binks » Tue Jun 15, 2004 10:05 am
(copied from my answer to other thread)
gears grinding means worn synchronizerrs. Before dishing out anythingtry this: Use Pennzoil Synchromesh (also called and sold under GM Synchromesh), the concensus here at solaraguy likes redline. BOTH products are equally good. I'd try changing these than dishing out anything. Don't know how to do this yourself..then get a local shop to replace the fluid for you. (much cheaper) and a lot of people complaining abbout grinding usually APPRECIATE this product later...
Postby whiteflash » Tue Jun 15, 2004 12:20 pm
thanks where do u put this fluid in
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby eugene5786 » Tue Jun 15, 2004 2:29 pm
my third gear seems to vibrate, could the be the synchros?
eugene5786
Postby 20SoLaRa02 » Tue Jun 15, 2004 3:00 pm
my thrid gear vibrates also ever since the short shifter.
-michael
20SoLaRa02
Postby Jai_Jai_Binks » Tue Jun 15, 2004 3:36 pm
whiteflash wrote:thanks where do u put this fluid in
HINT HINT: When's the last time you got your ATF and differential flushed.. Some people drain n fill (i did my drain n fill at 30K miles). at 60K miles, i'm planning a flush...so you might want to consider a complete flush..and fill those as desribed...
Postby Stock Solara SEV6 » Thu Jun 17, 2004 11:42 am
eugene5786 wrote:my third gear seems to vibrate, could the be the synchros?
My 3rd gear has always been that way also. When in 3rd, if you put a little pressure on the shifter, it will vibrate pretty bad. I've only got 11k miles, so I'm pretty sure it's not wear. Must just be normal?
2001 V6 5-speed
Stock Solara SEV6
Postby whiteflash » Thu Jun 17, 2004 5:04 pm
well i dont think its normal...
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby Stock Solara SEV6 » Fri Jun 18, 2004 7:34 am
whiteflash wrote:well i dont think its normal...
It may not be right, but based on responses it sounds like it is normal.
2001 V6 5-speed
Stock Solara SEV6
Postby dan99solara » Fri Jun 18, 2004 1:40 pm
mine does it too. if im in third or fifth and i push up a little bit on the shifter while im putting on gas it vibrates. obviously its normal if everyone's does it including the guy that has only 11k on his car. Now if you are shifting into third with the clutch fully pressed and it grinds going into third yes you have a problem and should consider a drain and refill of MTF (i like mobil 1's full synthetic fluid). but this might not stop it because it might be the syncros.
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
Postby bronzemaxell » Fri Jun 18, 2004 2:08 pm
dan99solara wrote:mine does it too. if im in third or fifth and i push up a little bit on the shifter while im putting on gas it vibrates. obviously its normal if everyone's does it including the guy that has only 11k on his car.
mine does the same thing ever since i got it, which only has 6 miles on the odometer then.
bronzemaxell
Postby whiteflash » Fri Jun 18, 2004 8:55 pm
they told me my synchors were messed up and now toyota doesnt sell synchros seperatley...... so they charge u a grand for the whole set
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby Jai_Jai_Binks » Sun Jun 20, 2004 6:43 am
whiteflash wrote:they told me my synchors were messed up and now toyota doesnt sell synchros seperatley...... so they charge u a grand for the whole set
did you even try the GM syncromesh or the redlines stuff. i say cus a LOT of celica people who have grinding gears use this..and are problemfree! I think a few people here use the redline product here....its cheaper to change the tranny fluid than replace the syncros...
