SolaraGuy.com • View topic - weird noise ???
weird noise ???
weird noise ???
Postby chinaxb0y » Mon Jun 21, 2004 10:24 pm
wassup you guys. umm i have this weird noise coming from the back passenger side by the speaker almost by the springs and shocks. everytime i hit a bump i hear that noise. what do u guys think it might be?? i'm thinking the shocks aren't tight on the top where the 3 bolts are. another thing do you guys know the easiest way to get to the rear shocks/springs without taking apart the whole back seat and everything? thanks for your help.
chinaxb0y
Postby Hsakuragi » Mon Jun 21, 2004 10:59 pm
did you change ur sway bar?
Hsakuragi
and also ur noise was like
"uhh...ekkk..." ?
Hsakuragi
Re: weird noise ???
Postby Mole » Tue Jun 22, 2004 1:38 am
chinaxb0y wrote:wassup you guys. umm i have this weird noise coming from the back passenger side by the speaker almost by the springs and shocks. everytime i hit a bump i hear that noise. what do u guys think it might be?? i'm thinking the shocks aren't tight on the top where the 3 bolts are. another thing do you guys know the easiest way to get to the rear shocks/springs without taking apart the whole back seat and everything? thanks for your help.
try pushing the car up and down w/ the trunk open. it might be easier if you have a friend push while you listen.
as for accessing those 3 bolts, the only way is to rip everything apart. unless you want to cut the cardboard cover panel.
Postby chinaxb0y » Tue Jun 22, 2004 11:27 pm
yea i did that. i opened the trunk and bounced up and down. and you can only hear that noise when i bounce up and down. so does that mean that i didn't tighten those bolts on the shock tower???
chinaxb0y
Postby impactX » Wed Jun 23, 2004 12:55 am
Swaybar endlink bolts are loose. <-- most probably.
impactX
Postby MalBandito99 » Wed Jun 23, 2004 10:05 am
Wow , I get this noise too and I just never got around to trying to diagnose it. Thanks, good thread.
MalBandito99
same noise...
Postby mcgervey » Wed Jun 23, 2004 12:37 pm
I had in my Grand Prix GT... turns out I changed the rear struts, but not the strut mounts as recommended, that's what the rattle is. Hopefully I'm years away from needing struts in the Solara...
mcgervey
