SolaraGuy.com • View topic - Tune up (sorry if repost)
Postby StockSolara » Fri Jun 25, 2004 8:27 am
I know your suppose to have tune-ups when your car hits certain milege. . . so what are those numbers and what do you have to do?
my car has 24,200 miles on it right now.
Thanks
StockSolara
Postby onefiend » Fri Jun 25, 2004 9:51 am
Tune up (as applicable) for 30k miles
Replace spark plugs (if needed, plugs are good to about 60k)
Replace distributor cap and rotor (if needed)
Inspect spark plug wires
Replace air filter (if needed)
Replace fuel filter (Toyota manual says change OEM fuel filter at 100k)
Replace PCV valve or orifice and hose (if needed)
Inspect PCV vent hose
Clean throttle body sludge deposits (if needed)
Remove and clean idle air control motor (if needed)
Check and adjust minimum air rate
Check and adjust throttle position sensor
Load test battery (if needed)
Clean battery terminal connections
Perform engine analysis
Scan engine control computer and perform self test
Clear adaptive memory and perform idle relearn procedure
Lube, oil, and filter change service
Drain crankcase oil and refill with new oil
Change oil filter
Check, and change as needed, underhood fluid levels (as applicable)
Power steering fluid
Automatic transmission fluid
Brake fluid
Clutch hydraulic fluid
Windshield washer solvent
Check crankcase vent filter condition
Check operation of all exterior lights
Check tire inflation and condition
Check, and change as needed, under vehicle fluid levels (as applicable)
Front differential
Manual transmission
Transfer case
Rear differential
Lubricate all grease fittings
Inspect drivelines and U-joints
Inspect steering linkage
Cooling system service
Pressure test cooling system
Drain coolant from block and radiator and save for recycling
Refill system with a 50/50 mixture of new antifreeze and water
Brake inspection
Tire rotation
Check air conditioner operation
If I am missing anything please add to this list.
onefiend
Postby StockSolara » Fri Jun 25, 2004 12:03 pm
wow. . . thank you
StockSolara
Postby groovespacer » Fri Jun 25, 2004 12:19 pm
How much does the tuneup's ussually run at dealership?
Also is 27 point check inspection necessary? and what does it involve?
groovespacer
Postby boneezy » Fri Jun 25, 2004 3:13 pm
full 30/60/90K is around or little more than $400-ish
u can do most of the tune-ups yourself
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby SolaraT » Sat Jun 26, 2004 6:48 pm
I love tune ups!
SolaraT
Solaraguy need mo power guy
Postby Astro » Sat Jun 26, 2004 7:08 pm
j0hn19 wrote:full 30/60/90K is around or little more than $400-ish
My dealer charged something like $259 w/car rental. I wonder what the average is?
Postby DatSRBoi » Mon Jul 12, 2004 11:29 pm
tune up is nice. But V6 spark plug changin isnt fun
Postby TheTamago » Tue Jul 13, 2004 6:23 am
I baby my solara a lot but its my first car and i can never afford a new car until I earn my way into life with a good earning job. =) I give it the Yellow/Green/Blue Services. I tend to give the yellow service every 3000-5000Mi or whatever my next checkup is at on the maintenance sticker on my windshield.
Had my tires replaced around 35K Mi with better performance tires I think but they're still on the 15" OEM Wheel/Rim I had equiped with my car. So far I have 46.5K Mi on my car. Nearing the point I guess when I need a transmission belt replacement hehe.
My brake pads were 40%front/50%rear from my 45K Mi maintenance and still stock from 2000. =)
TRD Air filter/TRD RSB. Debating if I can save up enough to throw on the 17" TRD type wheels and Tokico/Eibach setup.
TheTamago
Postby Jai_Jai_Binks » Tue Jul 13, 2004 7:35 am
I don't know what average is...but I personally wait for dealership coupons, $250 ballpark is what i pay for their 30K mile services.
Postby Jaimster » Tue Jul 13, 2004 7:06 pm
Off topic! But!
Jai, how the fashion-central-united-kingdom you have over 1400 posts? Your IP clocks you at close to 900 posts, I'm disturbed!!
... unless you changed your username or something.
Jaimster
Postby Jai_Jai_Binks » Wed Jul 14, 2004 8:59 am
Solara1.5 wrote:Off topic! But!
I really don't know. I went as jhbhatia (username) for the longest time, and then i changed that to jai (my first name). At home i have 2 laptops and one at work, so differnt IP addresses could be dependant on where i post from (right??)...Are you having a prob. with me postwhoring??? :D (j/p).
Edit: DId a check on statistics - wov! i'm at number 10 position... :angel:
