SolaraGuy.com • View topic - Amp trouble.....
Amp trouble.....
Amp trouble.....
Postby HKSV6SLE » Thu Sep 11, 2003 8:18 pm
just wondering how many of you have had problems with ypour amps blowing out....? my fosgate two channel amp is giving me a headache...cuz i blew it again....i was wondering if anyone else has/ or had fosgate amps in their cars...and if any of you ever blow out your amps...im about to pull all my fosgate stuff and trash it and get new stuff.......
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby kondo » Thu Sep 11, 2003 8:29 pm
I had a amp catch on fire because I was running 2 phosgate 12's off it but the amp were hooked up isobaricly and the amp was bridged so it was running at .5 ohms. But that was a autoteck amp, phosgate should be stable as low as .5 How much power are you running in your system?
your wires could be too small or you could just be blowing fuses because they are too small.
kondo
SolaraGuy StickerGuy
Postby Luc » Thu Sep 11, 2003 9:30 pm
The ONLY Rockford Fosgate amp that was 0.5-ohm stable was the old waffle style, 50m!!! Unfortunately, once RF made its way to BB, their quality hasn't been as reliable as before. RF amps never had built-in fuses as extra protection, so thus, check to make sure your power cable isn't touching metal anywhere.
1998 S/C'd 1MZ-FE A/T
Luc
Postby prophesized » Fri Sep 12, 2003 5:58 am
in the 2 years ive been in car audio the worst thing ive done is blow a fuse in my cadence amp. i was looking at it upside down when i hooked it up and switched where the ground and power wires go.
prophesized
Postby indiglosolara » Fri Sep 12, 2003 10:37 am
I had a friend running fosgate amps, she had alot of trouble also. she blew 3 fuses in less then 3 months of install and blew the amp 6 months later. She installed them with all the correct wire 4ga, and 4ga ground. then she switched to a crossfire amp and haven't had a problem since. alot of the newer even 1yr old amp were made with such poor quality.
I would probably go with a diff amp, jbl's are good amps, Phoenix gold, kicker and etc.
Do a search i was sure there was a talk about amps in the earlier months.
kenny
indiglosolara
Solara 2 xB
Solara 2 xB
