SolaraGuy.com • View topic - big brake kits
big brake kits
Postby SC V6 » Sun Jul 18, 2004 2:24 pm
don't need the big brake kit, it would help stoping... The S\c comes w\ an electronic boost controller
SC V6
Postby Mole » Sun Jul 18, 2004 10:02 pm
you don't have to install a big brake kit, however upgrading the existing brake system is something you should not look away from.
Postby MalBandito99 » Mon Jul 19, 2004 7:39 am
Get a set of Goodridge stainless steel brake lines, maybe some Brembo or Powerstop rotors, slotted or just plain, NOT CROSS DRILLED. And some new pads. Either some ceramic pads of good quality or some Porterfield racing synthetic pads.
MalBandito99
Postby Mole » Mon Jul 19, 2004 7:52 am
rotors are custom fit to that year car and are not universaly fit.
this upgrade should set you back about $300-400
w/o the rotor upgrade- $150-$200
Postby dmxtw33 » Mon Jul 19, 2004 9:41 am
why not cross drilled?
dmxtw33
Postby MalBandito99 » Mon Jul 19, 2004 9:45 am
Increased risk for rotor warping, brake pad more prone to crack, and decrease of brake pad life overall. Normal style rotors are fine for street and some track use, but slotting gives the brake less fade from repeated use and heat generated, and it cleans the brake pad surface by scraping it every time it passes over a slot which means it grinds up the pad to create better grip.
MalBandito99
Postby hari-bhari » Mon Jul 19, 2004 10:15 am
dmxtw33 wrote:why not cross drilled?
yea why not cross drilled. i thought slotted and cross drilled rotors were the best.....
hari-bhari
Postby MalBandito99 » Mon Jul 19, 2004 1:03 pm
Oh yeah, and more chance for rusting of the rotor and decreased structural durability of the metal rotor body.
MalBandito99
Postby indiglosolara » Mon Jul 19, 2004 2:23 pm
I have the brmbo cross drilled and slotted rotors...
they told me they put zinc on it so it doesn't rust but mine rusted anyways...
i've had mine on for about 25k not and they are warped... im using trd pads also...
im changing to brembo slotted rotors since it would do me best.. i wouldn't go with both.... IMO and from personal experience...
slotted only will do you just fine....
indiglosolara
Solara 2 xB
Solara 2 xB
Postby bkp_duke » Mon Jul 19, 2004 2:31 pm
yeah, brembo doesn't make cross drilled AND slotted rotors specifically for the warping issue
someone bought some slotted rotors and then drilled them out and sold them to you.
sux man
did you do a big-brake kit or just replace the OEMs w/ something the same size?
2000 Solara SLE V6, Silverstream Opalescent
TRD Body Kit, Charcoal Leather
TRD Shocks, Struts, RSB, and Air filter
Legal Tint (32%)
bkp_duke
Postby SolaraT » Mon Jul 19, 2004 2:51 pm
Yeah Brembo don't actualy make the rotors drilled and slotted. Either Slotted or Drilled. Not both.
Some other company messing with it and labeling it "Brembo" :lol:
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby SolaraT » Mon Jul 19, 2004 2:53 pm
MalBandito99 wrote:Get a set of Goodridge stainless steel brake lines, maybe some Brembo or Powerstop rotors, slotted or just plain, NOT CROSS DRILLED. And some new pads. Either some ceramic pads of good quality or some Porterfield racing synthetic pads.
Couldn't say it better myself! Thanks!
2007 VW GTI
SolaraT
