SolaraGuy.com • View topic - headlight out HID
headlight out HID
headlight out HID
Postby kondo » Thu Jul 29, 2004 9:03 pm
My passenger light has been out for a few weeks. I have mclough hid's anyway i thought it was the bulb so i tested it on the driver side its good. I hooked up the other balast and tested it and it also works on the drivers side. Is there a fuse that can be blown and if so where is it? or could the wiring be bad. Has anyone else had similar issues, I was thinking of trying a stock bulb tomorrow to see it that works.
Nick
99 sle, 03 evo
kondo
SolaraGuy StickerGuy
Postby 808Camry » Fri Jul 30, 2004 11:54 am
There's a small fuse box on the passenger front side. If I remember correctly the fuse is in there. Try using 15A or a 20A fuse not the stock 10A.
808Camry
Postby kondo » Wed Aug 11, 2004 6:33 pm
so today i finally decided to test a stock light to see if it would work and it did. So WTF both the balasts and the bulbs work but only on the driver side. The stock light is the only thing that i can get to work on the pasanger side. ANYONE................HELP
99 sle, 03 evo
kondo
Postby krawzyazn » Wed Aug 11, 2004 7:38 pm
kondo wrote:so today i finally decided to test a stock light to see if it would work and it did. So WTF both the balasts and the bulbs work but only on the driver side. The stock light is the only thing that i can get to work on the pasanger side. ANYONE................HELP
ok i did that to mine the other day check the fuse
for the headlight
Postby 808Camry » Thu Aug 12, 2004 12:01 am
Correction the fuse box is the small box on the drivers side. Make sure you have 15-20Amp fuses for the headlights. That's the only thing I can attribute it to.
808Camry
Postby krook » Thu Aug 12, 2004 3:39 pm
if you've got the McCullogh's, i'm pretty sure you lose the high beam. are you sure you're pluggin' it in right? there's only 2 prongs that will be attached. try and flash your highs and see if that passenger side bulb comes on.
krook
Postby kondo » Thu Aug 12, 2004 11:46 pm
The whole time it was a blown fuse. Its a little one and i could not see it the thing was a pain to get out but now its fixed.
99 sle, 03 evo
kondo
