SolaraGuy.com • View topic - Manual Tranny Swap COMPLETE!!!
Postby SC V6 » Wed Aug 04, 2004 7:09 pm
I've been hiding away in my garage for about 2 weeks, but im finshed... most of the wait was because of parts... I got anxious and started before parts arrived
Installed:
Kaaz Limited Slip
Spec Stage 3 (6-puck) clutch
Fidanza Lightened Flywheel
URD 190lph fuel pump
The Manual Tranny is in, and everything runs perfect.. just broke the LSD in today... I have to baby the clutch for a while.. but thats it
I have pictures but I have them on the camera, and I will post soon...
Everything was done by myself and a buddy of mine in my garage
No CEL codes.. no problems
later
SC V6
Postby geminimouse » Wed Aug 04, 2004 7:14 pm
Nice!!! Can't wait to see the pics.
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby onefiend » Wed Aug 04, 2004 7:36 pm
wow!!! impressive....good job to you and your buddy, cant wait to see the pics.
onefiend
Postby EricSol » Wed Aug 04, 2004 8:04 pm
Did you swap the ECU or spoof it into thinking the auto is still there?
2004 Pontiac GTO 408ci 535 whp all motor
1999 Solara 296 whp
EricSol
Postby hari-bhari » Wed Aug 04, 2004 8:14 pm
how much did it cost?!
hari-bhari
Postby SC V6 » Wed Aug 04, 2004 8:32 pm
I was going to use a Manual ECU, but the salvage yard I got it from... didn't give me a key that got past the transponder... so I couldn't get it past the Theft ... wouldn't turn over.. so I just tricked it
SC V6
Postby Mole » Wed Aug 04, 2004 9:58 pm
sweetness!!!!!
was it as hard as we have all thought it was before?
Postby SC V6 » Thu Aug 05, 2004 12:38 am
it really wasn't that bad.. the only part that was hard (not bolt on) was the clutch pedal.. which wasn't that bad... Everything else was bolt on, and was pretty easy... but I thought while I was doing the swap, I needed the Lightened flywheel, stage 3 clutch, and the LSD...
Really the LSD install scared me.. You need to order a 91 MR2 turbo speed sensor ring from the DIfferential, and the snap ring, as well as the new speed sensor ring for the sensor itself.. which was hard to get since there were only 3 coming into the US from Japan... but I got all that, and got the LSd installed.. the install on the LSD was very involved.. I had to tear the tranny completly apart to get the stock differential out.. overall... not that hard
Just lots of hard work... and sweat.. it was so humid a majoridity of the time
SC V6
Postby 808Camry » Thu Aug 05, 2004 2:21 am
Whoa, you did the near impossible. Congrats, if you don't mind how much did this all cost you and how much diff is the power?
808Camry
Postby 808Camry » Thu Aug 05, 2004 2:22 am
How did you spoof the ECU? Also was everything pretty much bolt on except for the clutch pedal?
808Camry
Postby kubi » Thu Aug 05, 2004 7:29 am
SC V6 wrote:it really wasn't that bad.. the only part that was hard (not bolt on) was the clutch pedal..
Please stop humping my car, owner privilege!
kubi
Postby 99V6solaraSE » Thu Aug 05, 2004 7:58 am
man madd propz... thats cool. About how much $$$ did u spend? im plannin on doin the same thing pretty soon.
99V6solaraSE
Postby SC V6 » Thu Aug 05, 2004 10:29 am
well... I went to a local salvage yard.. and got everything I needed for $1000... that was a ECU, pedals, shifter assembly, shifter cables, tranny, stock flywheel, clutch and pressure plate, speedo, axles, slave cylinder, master cylinder.. I think I got all of it.. but I got that all for $1000... then I had to upgrade.. so I got the LSD ($890), lightened flywheel $350, URD fuel pump $95, and stage 3 clutch $350... I had to go get gear oil, gasket maker (had to tear the tranny apart) and some tools and things, but over all I say it was about 2500-3000 for all the upgrades and parts and tools...
SC V6
Postby SC V6 » Thu Aug 05, 2004 10:30 am
O yeah.. the best part about this is... I have a bigger brake booster over a stock manual and I have traction control...
oh yeah.. I got the ECU to be tricked.. by taking my Auto tranny apart and pulling the celinoids out... basically I took all the sensors that the ECU wanted to see out of the tranny.. and pluged them in.. and hid them in the engine bay... not too hard.. that only took 30 min
SC V6
Postby SC V6 » Thu Aug 05, 2004 10:33 am
oh yeah.. the power KICKS AS$.. I love it.. the LSD pulls me threw the corners like HEL#... and it just takes off so much faster.. I LOVE it... I was skeptical half way threw.. I had some doubts and got worried.. but then when it was done.. and everything works great... I knew it was a good thing that I did it.. the Auto Overdrive clutches were fried anyway.. the tranny fluid in the Auto was brown and weird lookin.. w\ chunks in it...
SC V6
