SolaraGuy.com • View topic - custom six speed?
custom six speed?
custom six speed?
Postby SC V6 » Thu Aug 19, 2004 8:50 am
would it be possible to have custom gears made for the 5 speed tranny, so it had an extra gear? I was just thinking about this... anyone have any ideas?
SC V6
Postby Mole » Thu Aug 19, 2004 9:03 am
hmmm come to think of it. i think it can be done.
space should not be the issue since the celica gts had a 6sp trans.
how much more $$$ you plan to drop down dude?
Postby SC V6 » Thu Aug 19, 2004 9:56 am
Im just thinking... I took the tranny apart, and I think that the inside had some room, but the thing is you would have to move the reverse lever and change things around, but it seems possible... I wonder if the Celica Six Speed Bolts up, or if you would need a bell housing convertor.. its possible.. I think it would be awesome to have a Six speed..
SC V6
Postby PASolara » Fri Aug 20, 2004 7:31 am
I agree dude i use to have a Spec v 6 speed those shorter gears are nice. If there was any way posible to make the Solara a 6 speed i would. So let me know how u make out :lol:
PASolara
Postby SC V6 » Fri Aug 20, 2004 7:50 am
IM thinking the only way would be the celica six speed w\ an adapter so it bolts up to the Engine... the housing won't fit an extra gear
SC V6
Postby that1mexguy » Fri Aug 20, 2004 11:15 am
if you guys are able to pull this offer.. you got a possible buyer here!!! my car keeps BEGGING me for a 6th gear!!! :lol:
that1mexguy
Postby SC V6 » Fri Aug 20, 2004 11:35 am
I know what you mean
SC V6
Postby hari-bhari » Sun Aug 22, 2004 7:56 pm
what would be the point of adding an extra gear? all the original gears would still have the same ratios, so i guess 6th would give u a higher top speed, but thats about it....or i could be completely wrong....
hari-bhari
Postby Rudy » Sun Aug 22, 2004 11:28 pm
a really high speed highway cruising gear would actually be quite practical in my opinion, but that could be done by just replacing the 5th gear.
99 Solara V6 5SPD
Rudy
Postby Mole » Mon Aug 23, 2004 12:00 am
hari_trivedi wrote:what would be the point of adding an extra gear? all the original gears would still have the same ratios, so i guess 6th would give u a higher top speed, but thats about it....or i could be completely wrong....
haha. its impossible to just add another gear to the curent 5sp. so the point of having the same ratios just wont be.
Postby PASolara » Mon Aug 23, 2004 8:49 am
Yea no sence on adding one the whole idea od six speed is to have shorter gears. Its kinda like putting a Rear in a RWD makes it quick off the line and mid range. LIke my specv i would shift into 3rd about the same time most 5 speeds shift into second
PASolara
Postby Fletch » Mon Aug 23, 2004 10:16 am
I think the problem is 2nd is too tall. A problem with just replacing 2nd gear with a shorter gear is that it might put you below the powerband from a 2-3 shift.
2006 Legacy GT spec.B
Fletch
Postby PASolara » Mon Aug 23, 2004 11:32 am
I agree i think our best bet is to try and get a celica 6 speed to work. But are those tranny's tough thats one good thing about our tranny they are pretty tough.
and whats the celica 6 speed gear ratio compared to ours
PASolara
Postby i20solara02i » Mon Aug 23, 2004 1:17 pm
how the hell would the celica gts tranny work? the engine code on the celica and the solara are different. you would have to find a shop and custom everything.
i20solara02i
Postby PASolara » Mon Aug 23, 2004 2:02 pm
who knows the Mr2 turbo is differnt also and we have the same tranny and use the same clutch :drinking:
PASolara
