SolaraGuy.com • View topic - Import Performance Parts 1MZ-FE engine build-up . . .
Postby TRD_solaRa » Mon Aug 30, 2004 5:58 pm
I came across this website that lists some internal engine modifications . . .
Complete Gasket Set
Performance Copper Head Gasket
ROSS Forged Pistons
(87.5, 88mm) and
(7.8-1, 8-1, 8.5-1, 9.1-1 comp ratio)
Performance Rings
Performance Wrist Pins
TOGA HP Main Bearings
TOGA HP Rod Bearings
Thrust Washers
Timing Belt
Expansion Plugs
=$1569.00
what do you guys think . . . the ratio specs they list would mean that you'd have to bore out quite of bit of the engine. any input is g. peace guys & gals.
http://www.importperformanceparts.net/imports/pek-toyota.html[/b]
TRD_solaRa
Postby SC V6 » Mon Aug 30, 2004 7:01 pm
NICE FIND!
SC V6
Postby SC V6 » Mon Aug 30, 2004 7:04 pm
GROUP BUY!
SC V6
Postby 99V6solaraSE » Mon Aug 30, 2004 7:17 pm
so what exactly does it take to install at the stuff ? as you can see im still a newbie and just know the basics... so yah.. i really dont know what all that stuff does.
99V6solaraSE
Postby SC V6 » Mon Aug 30, 2004 7:19 pm
the forged components would allow the engine to handle more boost.. like handle 10psi no problem.. it would beef the internals of the engine up quite a bit
SC V6
Postby 99V6solaraSE » Mon Aug 30, 2004 7:25 pm
i figured itd do somthing like that. LoL ... what exactly would it take to install all that stuff? i wouldnt have to modify anything would i?
hey btw i plan on attemting to do a manual tranny swap in the future..
was that difficult to do? and if my memory serves me right, you did it yourself? about how much did the parts cost and what kind of parts did you have to buy? have you faced any problems with it? does it feel like any other car that is stick? about how much do u think labor would cost if i got someone else to do it for me since i cant do it myself..?
99V6solaraSE
Postby SC V6 » Mon Aug 30, 2004 7:39 pm
I got all the parts that I needed for 1000.... but then i upgraded... it wasn't that bad, the only thing that really caused a problem was the install on the LSD.... which wasn't that bad... if u took it to a shop it would cost at least a grand... I did do it myself... it takes dedication... I wouldn't recommend it unless u love working on cars, and have lots of tools...
as far as install on this kit, it would have to have the short block dropped.. and I think it has to be bored out... as well as the rings gapped...
yes it is like any other stick... except its better.. I still have my automatic start... I have a bigger break booster that came w\ the autos... I still have cruise control...
SC V6
Postby Astro » Mon Aug 30, 2004 10:43 pm
Nice! I'd like to see someone put that new stage 3 twin turbo kit coming out with that low compression. :o
Postby boneezy » Tue Aug 31, 2004 9:03 am
Astro wrote:Nice! I'd like to see someone put that new stage 3 twin turbo kit coming out with that low compression. :o
theres twin turbo kits??
if so, are you talking about the twin turbos that came on the sienna?
1999 SE-V6 5spd
160,xxx miles
boneezy
Re: Import Performance Parts 1MZ-FE engine build-up . . .
Postby Ryan » Tue Aug 31, 2004 8:11 pm
TRD_solaRa wrote:I came across this website that lists some internal engine modifications . . .
Complete Gasket Set
ROSS Forged Pistons
(87.5, 88mm) and
Performance Rings
Thrust Washers
Timing Belt
Expansion Plugs
=$1569.00
this is what I exactly need But Unlike the other guys I will have a shop installed this to my Solara good find brother
Ryan
Postby 99V6solaraSE » Tue Aug 31, 2004 9:22 pm
what stage3 turbo kit are u talking about? I didnt even know that they had a stage 3 turbo kit for the 1mz
99V6solaraSE
Postby Astro » Wed Sep 01, 2004 9:44 am
99sOLaRaSEaUto wrote:what stage3 turbo kit are u talking about? I didnt even know that they had a stage 3 turbo kit for the 1mz
This was taking from ToyotaNation by Image
The TT kit will work on any 1mz engine (including VVT-i).
It's going to be decently expensive. But trust me, it is worth the money.
1MZ (Compatable VVt-i engines)
Stage 1
50% gain @ 5psi
Comes with all the plumbing and a tunable black box
Stage 2
125% @ 10psi (Unofficial Results)
Same as Stage 1 plus intercooler
Stage 3
no data, will be running at 15psi
same as Stage 2, plus forged interenals, O2 sensors, plus more
3.3L (Compatable with VVT-i Engines)
Stage 1
25% gain @ 5psi (Unofficial Results)
October is the date being shot for, however nothing is final. The Head Mechanic at SC also works on a Pro NASCAR team. So time varies.
But the kit is still on track. So keep saving your pennies
Postby SC V6 » Wed Sep 01, 2004 10:31 am
I dunno why they would do one for the VVT-i.. the exhaust and intake overlap too much w\ the cams... basically the boost runs out the exhaust... they why u can't really boost a Vtec engine
SC V6
Postby Ford_Fixorrepairdaily » Wed Sep 01, 2004 12:44 pm
dude help me with a manny swap, i'll pay you!! How lond did it take you to do the complete manny swap sc-v6.
Postby SC V6 » Wed Sep 01, 2004 12:51 pm
actual time working??? I got anxious and started before I had all my parts... so i had the auto out of the car and the H-frame and all that dropped in about 8 hours or actual work... then I had to wait for LSD parts, and the sensors that you need to get from Toyota, those were on back order, and it took a week to get those. If you were just to put a manual up, and forget about putting in a LSD and things.. it wouldn't be that long at all... I would say, w\ all the parts there when u started.. and some experience w\ all the tools, it would take at least 3 full days of work.. but then u could always run into problems...
SC V6
