SolaraGuy.com • View topic - 9006 to 9005 conversion
Postby Ford_Fixorrepairdaily » Fri Sep 10, 2004 10:42 am
i was wondering if anyone had done this before. i was planning to have to do a 9006 conversion to 9005 . the only thing that i worried about is that it might burn too hot and melt something.
2002 Solara SLE V6 - Sold =*(
2006 S2000 - Weekend G Ride!
2009 - Fit Daily Grinder
Postby S99Solara » Fri Sep 10, 2004 2:48 pm
is this for fog or headlight? if for fog i heard it's not good to do it because the fog are not as focus. as for heat you shouldn't have to worry because it's only slightly higher will not burn/melt for sure.
06 4Runner V8 SE
98 1MZ-FE Camry
SOLD! 1999 SE V6 5 Speed,Clutch Masters Stage 2 Clutch Fidanza Lightweight Flywheel, Tein / Tokico, Philips power2night GT150 H4, TWM Shortshifter, Optima Red Top Battery, TRD RSB
S99Solara
Postby SolaraT » Fri Sep 10, 2004 3:47 pm
hehe I just did this last night!
Check this out... http://home.comcast.net/~solarat2/retro ... psules.htm
Pics are with 9005 and the DIY for it is all the way down the page.
It can't be that much hotter as s99solara said. You can always upgrade the harness if you want that piece of mind.
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby MGLax13 » Fri Sep 10, 2004 5:33 pm
I have this done in my fogs, and I finally got to test it out the other night with my yellow bulbs on my way home from the east end of Long Island. Giant improvement over stock 9006's and those hyper blue 9006's. I dunno if it was just the yellow part of the whole combination.
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby SolaraT » Fri Sep 10, 2004 5:38 pm
Everything took to play. 9005 is perfect brightness. I had yellow 9006 bulbs before and it was a joke. Not bright at all.
You all think we should upgrade the harness or the fuse?
2007 VW GTI
SolaraT
Postby 808Camry » Fri Sep 10, 2004 8:32 pm
I did, its easy and brings lots of light but it discolors the light shield and possibly your lens
808Camry
Postby Ford_Fixorrepairdaily » Sat Sep 11, 2004 1:24 pm
dang those capsules look nice ! im thinkin about doin that now. :o
