SolaraGuy.com • View topic - Engine Reuild Suggestions
Postby Paladin06Greg » Sun Sep 12, 2004 12:36 pm
Well, it looks like I've had the misfortune of piston ring failure. Yea, I know it seems crazy with just 27000 miles but, I've got a lot of crankcase vent tube blow back with some oil.
So, while I'm in there how about suggestions for pistons, rings, valve springs and whatever else I should do while it's open. Don't foget to tell me where to get them.
Thanks
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SC V6 » Sun Sep 12, 2004 1:09 pm
I would get total seal piston rings... they make a gapless top ring which are awesome.. they are chrome.... what I did was called Total Seal, and got an adress and sent them a piston, and they would fit it w\ the perfect rings... http://www.totalseal.com/totalseal3.html as far as pistons.. I thought u had forged components??? I would get JE forged pistons...
so did u have a leak down test?? what happened? weren't you running forged pistons??
SC V6
Postby Paladin06Greg » Sun Sep 12, 2004 1:53 pm
No leak test until Monday. All the shops are too busy or closed. The pistons, like the rings are OEM.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SC V6 » Sun Sep 12, 2004 2:12 pm
gotcha.. I think I had you mixed up w\ someone else for the forged pistons.. I bet you ran lean and cracked a piston lan.. possibly more than one.. thats my guess.. u can either bore out the short block, if the scratches arn't deep enough and get aftermarket pistons.. or a new short block
SC V6
Postby shidosha01 » Sun Sep 12, 2004 3:37 pm
Greg,
You've got a PM.
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Postby Paladin06Greg » Mon Sep 13, 2004 9:43 am
Made the call this morning. We had a good talk..
Paladin06Greg
Torqued Solara
Torqued Solara
Postby adam2562 » Tue Sep 14, 2004 12:53 pm
i have a shortblock with pistons and rods and crank but it needs rod bearings.. if u wanna buy it from me... the shortblock has less than 10k on it and came from an Avalon.. (same block)
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby Paladin06Greg » Tue Sep 14, 2004 2:28 pm
8) Thanks but no thanks!
Paladin06Greg
Torqued Solara
Torqued Solara
Postby adam2562 » Thu Sep 16, 2004 8:23 am
no problem man... its just laying around i thought i would need it.. but it turns out my engine with 152k is doing really good..
adam2562
Users browsing this forum: Google [Bot] and 53 guests
