SolaraGuy.com • View topic - car shakes a lil...
car shakes a lil...
car shakes a lil...
Postby s15lara » Wed Sep 15, 2004 11:18 am
ok, ive noticed that when my car warms up, it tends to shake a lil. if i tap the acclelerator a lil bit, it stops for a min and then when it idles again it starts to shake again. i thought it was cuz i needed a tune up, but i did it about 2 months ago and its still there. when i put the A/C on, it shakes a liil diff. the streering wheel shakes as well, but it shakes when im standing still...dont know what the prob is...im lost. any ideas guys...? let me know, id much appreciate it.
s15lara
Re: car shakes a lil...
Postby Too Bzy » Wed Sep 15, 2004 11:32 am
solara_supra_hopeful wrote:ok, ive noticed that when my car warms up, it tends to shake a lil. if i tap the acclelerator a lil bit, it stops for a min and then when it idles again it starts to shake again. i thought it was cuz i needed a tune up, but i did it about 2 months ago and its still there. when i put the A/C on, it shakes a liil diff. the streering wheel shakes as well, but it shakes when im standing still...dont know what the prob is...im lost. any ideas guys...? let me know, id much appreciate it.
Kind of sounds like the motor mounts are getting weak to me. Check those.
Charles "Cee-Jay" Hughes
99 TRD Solara S/C LB GP Ed. 23 of 35
86 Supra w/ 6M-GTE
Too Bzy
Postby MalBandito99 » Wed Sep 15, 2004 11:57 am
I get this problem too. Have been for about almost 5k miles or so, and no one, not my mechanic or others, notice it or know what Im talking about. I know when I first got the car at low miles it wasnt like this. It used to be like the engine was non-existant. Now I can feel it a bit, but its still better than most other cars.
I hear that it could be transmission issues, maybe a flush or something would help? Anyone else chime in please, help us.
MalBandito99
Postby Jai_Jai_Binks » Wed Sep 15, 2004 12:00 pm
if your a pre 2001 4 banger (ie. 5sfe) dude...then your SOL. ALL 5sfe's have mild shakes. This problem is not isolated to Solara's alone, camrys and celicas that came with 5s motors are also plagued with this. If the shakes are like a lil' vibrator...then i'd get it checked..but if its miniscual then i'd wouldn't worry about it.
Postby s15lara » Wed Sep 15, 2004 12:09 pm
well i have the v6 '99 se. its not that miniscule and it is annoying me. but like malbandito said, no one can notice it. only i can. i can feel it when i stop, but it seems like no one else can. im probably going to take it to my mechanic and see what he says. hopefully its nothing big.
s15lara
Postby Jai_Jai_Binks » Wed Sep 15, 2004 1:00 pm
than it could be motor mounts, or tranny mounts. You over 100K miles?
Postby MalBandito99 » Wed Sep 15, 2004 1:07 pm
solara_supra_hopeful wrote:well i have the v6 '99 se. its not that miniscule and it is annoying me. but like malbandito said, no one can notice it. only i can. i can feel it when i stop, but it seems like no one else can. im probably going to take it to my mechanic and see what he says. hopefully its nothing big.
i got the same damn problem as you. wow, hope it isnt that big of a problem cause ive been lax on getting it around to shops to see if other can give me another opinion. Ive just been thinking a transmission flush would help it out some, and a tranny cooler installed would help keep it that way, even though it doesnt have anything to do with the ATF getting dirty.
and im at a bit under 23k miles. Got the car at 7.5k.
MalBandito99
Postby s15lara » Wed Sep 15, 2004 3:24 pm
i have 76k miles. you guys really think that it could be the motor mounts? i sure hope not... i guess that ill have to go to my mechanic to check to see if its the motor mounts. if it is the motor mounts how much would it cost to fix them? any1 know?
s15lara
Postby Turbosolara » Thu Sep 16, 2004 12:16 am
I think possible cuases could be:
dirty air filter or spark plug
dirty A/F raito sensor or it is waiting getting warm up
dirty injector
dirty throttle body
dirty intake maniford/valve
EGR leaky
whatever mod you did mess up a little
Postby DatSRBoi » Thu Sep 16, 2004 8:01 pm
Wowzie. Ok. The vibration is for sure annoying but you will start feeling it in any car ever made in this world most likely unless its a super luxury car then its more smooth out. As you drive your car on and on your engine just begins to break in and loosen up. The vibration is a normal thing and can not be stop to any point. It really just means that your engine is powered freely and broken in. BUT as more miles are added and so fourth of running your engine, it will start to increase due to yes drity this and that in your engine. The only way you can really stop it is go pro and redoing your engine every 10 to 15 G miles haha which that be crazy.
Postby kondo » Fri Sep 17, 2004 1:27 pm
My car shakes hella bad all the time when it idles. If i put it in neutral it shakes less but when the car is in park or drive it sounds really bad and my check engine light starts flashing. I pulled the code awhiel back and it said i was having a missfire in cylinder #1. You are not alone
kondo
SolaraGuy StickerGuy
Postby DatSRBoi » Fri Sep 17, 2004 1:35 pm
Wow..Guess its true....."SH*T HAPPENS"..But then when I think about it, toyota makes one of the best long lasting cars. So I wonder how all the other cars do.
Postby krzyray » Sun Sep 19, 2004 9:09 pm
Probably a dirty throttle body... I had the same exact problem. Do a search and find my old thread.
krzyray
