SolaraGuy.com • View topic - lowered car alignment
Postby Masshole » Fri Oct 08, 2004 5:48 am
Don't flame me I searched...
I have the tokico/eibach combo suspension set up lowering my car 1.5". The car has been pulling to the left so I took it in for an alignment. I have the free lifetime alignment deal from firestone. When I took it in they told me they couldn't align it properly because it's lowered. They said they'd do their best but it feels like they didn't do jack shhh....
Are these guys just idiots and I should try somewhere else? I've lost a lot of respect for firestone's work over the years - just another example of you get what you pay for.
Any recommendations are appreciated...
Thanks,
Kevin
99 Solara SE w/ tokicos and eibachs - fun around corners
86 Mustang GT (lots of goodies) - fun in straight lines(SOLD)
Masshole
Postby TadS » Fri Oct 08, 2004 5:59 am
It can be done, my local tire shop (that's not all that impressive) and my dealership have both aligned my car, which has a lower drop than yours, and so it can be done.
TadS
Lowered car
Postby SleeperSolara » Fri Oct 08, 2004 7:11 am
Try a camber kit.
It should straighten those tires out.
Postby Masshole » Fri Oct 08, 2004 7:24 am
what exactly is the camber kit? how much? where to get it?
I feel like a decent shop should be able to align it... I don't understand why these guys said they couldn't do it... ??
Masshole
Postby xsolara33x » Fri Oct 08, 2004 7:53 am
wheel pro here in my area aligned my car just fine. My car was pulling to the left and now it isn't. They should be able to do it.
xsolara33x
Postby Jai_Jai_Binks » Fri Oct 08, 2004 9:42 am
firestone by my side does work on lowered cars. Maybe your problem is not alignment but its camber as others suggested. Toyota 'generally' don't need camber kits; but occationally some of us do need it.
Postby Astro » Fri Oct 08, 2004 10:02 am
Masshole wrote:what exactly is the camber kit? how much? where to get it?
Check this site out...
http://eibach.com/cgi-bin/htmlos.exe/00216.1.1571544541700017044
Postby Ford_Fixorrepairdaily » Fri Oct 08, 2004 11:16 am
did you check your tire pressure? :D
2002 Solara SLE V6 - Sold =*(
2006 S2000 - Weekend G Ride!
2009 - Fit Daily Grinder
Postby cruze105 » Fri Oct 08, 2004 12:44 pm
i have free liftetime alignment from firestone as well, they said to me, same thing that they will try their best to align it,and they did a good job.
cruze105
SolaraGuy JerseyMan
SolaraGuy JerseyMan
Postby SleeperSolara » Fri Oct 08, 2004 1:28 pm
Check this out: http://eibach.com/cgi-bin/htmlos.exe/00 ... 1700017044
Camber adjust the tire left and right, to have the tires hit the pavment square.
There is a camber for front and back, but that is between the top of the shock tower, and the shocks themselves.
The camber kit will look like a "U" plate, wit some bolts on it to adjust it from left and right.
Postby Astro » Fri Oct 08, 2004 11:15 pm
I already posted the same thing. :drinking:
Postby lazyboyz69 » Sat Oct 09, 2004 1:47 am
http://www.tirerack.com/suspension/Susp ... &x=125&y=5
you can get the camber kit off the link above... its like 28 for the front and 28 in the back.... they are backordered for two weeks so i'm still waiting on mine.... and there eibach
lazyboyz69
Postby HKSV6SLE » Mon Oct 11, 2004 1:42 am
i had to get my camber corrected. a speciality shop sould be able to vustom fabricte new ones for cheap.
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby all_red » Mon Oct 11, 2004 4:18 pm
They told me I needed a camber kit, but I didn't get it and my car was fine. I also have the lifetime alignment from Firestone and I think they do a good job.
5-speed V6.
TRD Supercharger.
TRD Short Throw Shifter.
Tokico/Eibach combo.
all_red
Postby Jai_Jai_Binks » Tue Oct 12, 2004 1:06 pm
:raiseshands: Yeah, i'm also having the lifetime alignment from firestone!
