SolaraGuy.com • View topic - Y-pipe
Y-pipe
Y-pipe
Postby SleeperSolara » Fri Oct 08, 2004 8:01 am
I was thinkin' about gettin' an OEM Y-pipe from a salvage yard, and cuttin' out the Catalyic converter and stickin' a pipe slightly larger than the OEM piping, and clamping it down, or gettin' someone to weld the pipe onto the OEM pipe.
In other words stick a pipe slightly bigger than OEM piping in place of the Catalyic converter.
Would it effect the O2 sensor??
Postby Fletch » Fri Oct 08, 2004 10:14 am
You could always just gut the cat with a flexible rod or whatever. I was kind of thinking about it too. Currently my county does not have emissions testing but I think it's coming in a few years...
It shouldn't affect the pre-cat o2 sensor but the rest of them may set CEL for emissions codes. I don't know if simulators would work or if you can just plug the bungs and let the o2 sensors breathe ambient air, if you could find some way to mount them.
2006 Legacy GT spec.B
Fletch
