SolaraGuy.com • View topic - Installing Boost and EGT gauges
Postby all_red » Wed Oct 13, 2004 3:50 pm
I want to install a boost gauge and an exhaust gas temprature gauge on a dual apillar gauge pod. The shop quoted me $150 for painting the pod and installing the gauges, is that fair?
5-speed V6.
TRD Supercharger.
TRD Short Throw Shifter.
Tokico/Eibach combo.
all_red
Postby Mole » Wed Oct 13, 2004 9:42 pm
painting the gauge? installing the boost? installing the EGT? (those are the two gauges i have setup)
you can do that yourself.
as for installation, thats EASY!
just have to have the correct tools and patience.
Postby all_red » Wed Oct 13, 2004 10:25 pm
Don't you have to drill through the headers for the EGT gauge? and through the firewall for the wires to go through?
5-speed V6.
TRD Supercharger.
all_red
Postby Mole » Wed Oct 13, 2004 10:26 pm
EGT- yes, you make a small hole through the exhaust manifold.
firewall- there may be existing ones already.
Postby Yanks0114 » Sat Oct 16, 2004 4:25 pm
There are holes already going through the firewall, they are just filled with a rubber grommet
Postby WortownSolara » Mon Oct 18, 2004 6:29 am
though i must say 150 isnt bad at all, at least up here in New England, it would cost me 20 dollars just for the paint for the match. Then the labor to run the lines, though you might get a better understanding of your car if you do it yourself. A better appreciation for it....at the least.
If it doesn't kill you.....it only makes you faster!
WortownSolara
Audio Guru
Audio Guru
