SolaraGuy.com • View topic - Thinkin about getting these rims
Postby whiteflash » Sun Nov 14, 2004 11:40 pm
im not sure if they fit can anyone reassure me http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7934016902&category=43958
offset is 45mm and 5 x 114.3
Injen w/CAI Extension
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby Ryan » Mon Nov 15, 2004 3:56 am
I had the motegi dp5 on my solara for 3 days before I sold it has same specs as the dp6 it does rub with the struts on turns I had the tokico/tein combo 45 offset is up there our max I think is 42 but I could be wrong hope that helps
Ryan
Postby michaels artic frost » Mon Nov 15, 2004 6:57 am
Looks nice! Liking the lip on that too.
Updated 06/01/12: Michael T's
Postby SleeperSolara » Mon Nov 15, 2004 8:46 am
Yeah it nice.
Would look good on your Solara.
Postby indiglosolara » Mon Nov 15, 2004 10:13 am
with 18x7.5 you would want to go with +42 offset or lower. +40 offset would be better.. if you get anything with 8" width rims you should go with +38 or lower.
only becuase if you are lowered on tokico or even stock struts. it can rub.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby DonkeKong » Mon Nov 15, 2004 10:45 am
yea, I hav 18x8 rims and i initially had 245/40/18's on them and that rubbed on the strut and inside the fender on the back. So, i got 225/40/18's and its perfect now. So, yea i'd def listen to wat they said :roll: . Anyway, good pick on rims, I like em.
DonkeKong
Postby whiteflash » Mon Nov 15, 2004 10:59 am
so i they wont fit no matter wat tire width
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby whiteflash » Thu Dec 09, 2004 12:53 pm
so if i get 225/18/40 they woudl fit fine
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby DatSRBoi » Thu Dec 09, 2004 9:49 pm
Sorry little of topic but so the whats the 225/40/18 . I know 18 is the rim, 40 is the tire thickness dealio, so is the 225 the offset? sorry confused. Dont really get the tires and rims thing yet.
Postby indiglosolara » Thu Dec 09, 2004 10:10 pm
DatSRBoi wrote:Sorry little of topic but so the whats the 225/40/18 . I know 18 is the rim, 40 is the tire thickness dealio, so is the 225 the offset? sorry confused. Dont really get the tires and rims thing yet.
the first set of number is the width of the tire.
if you go higher in width you can go with 235, 245, 255
225/40/18:
225
^Width in MM Typically 225 is made for anything from 7" to 8"
40
^Side wall in MM
18
^Wheel Size
indiglosolara
Solara 2 xB
Solara 2 xB
Postby whiteflash » Fri Dec 10, 2004 11:29 pm
so if i do 225/40/18 they will fit with the 45 offset
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby DonkeKong » Sat Dec 11, 2004 12:20 am
I'm pretty sure you can fit those rims ez. i think you're gunna be best with 245/40/18, but 225/40/18 should work too. I'd rather have the 245's cause those would get a little more traction i think. thats how I understand it anyway
<http://www.cardomain.com/memberpage/729386>
1999 Solara SLE V6
DonkeKong
Postby indiglosolara » Sat Dec 11, 2004 9:49 am
DonkeKong wrote:I'm pretty sure you can fit those rims ez. i think you're gunna be best with 245/40/18, but 225/40/18 should work too. I'd rather have the 245's cause those would get a little more traction i think. thats how I understand it anyway
245 is typically too wide for the solara. Some have trouble with 235.
I've gone thru so many sets of wheels and was told to stay away from 245 even with 8.5 width rim from every shop i have been too.
If you want to be sure you can Call Vic and Discount tire in El monte. Look it up on yahoo. hes a expert on rims I always to go him if i have anything wheel/suspension wise that needs to be done.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby whiteflash » Sat Dec 11, 2004 11:39 am
damn I want those rims so bad
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby TRD_solaRa » Sat Dec 11, 2004 8:31 pm
Yea 245 is DEFINITELY toooooo wide for Solaras . . . unless you plan to widen your fenders. 245s are better on 8.5-9" wide rims, but being that our cars can fit 8.5" I still would say that you shouldn't use such wide tires. Yes you'd get more traction, but you'd get some phatty rubbing too.
TRD_solaRa
