SolaraGuy.com • View topic - ebay intake
ebay intake
ebay intake
Postby SEsolara2000 » Sat Jan 22, 2005 7:54 pm
i got an ebay short intake on my 5SFE solara right now, all the hoses hooked up right i think. Just wondering if i should trash the filter that came with it for a K&N. if its worth it ill get it and if i can make a cold air extension somehow, please give me your ideas on where to put the filter.
2000 Pearl White/Gray Auto SE 2.2 w/intake
http://www.cardomain.com/id/sexysolara00
SEsolara2000
Postby krawzyazn » Sat Jan 22, 2005 7:58 pm
filter is a filter use it till it dies
Postby indiglosolara » Sat Jan 22, 2005 8:12 pm
OT... But is that a 2 tone solara i c????
wow... thats the first of that color i have seen...
interesting..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby SEsolara2000 » Sat Jan 22, 2005 8:59 pm
ive never seen another solara in my color combo either, my dad got it brand new in 2000 and it was the only 4 banger on the lot with 3 V6's. My dad didnt want to spend 5000 for a V6 so he got the only 4 banger.
SEsolara2000
Postby krawzyazn » Sat Jan 22, 2005 11:38 pm
seen one in OC like that at buena park toyota lolz
Postby Whatever » Sun Jan 23, 2005 3:55 am
krawzyazn wrote:seen one in OC like that at buena park toyota lolz
hmm..buena park, the place where I brought my car. 8)
Whatever
Postby jazzlara » Sun Jan 23, 2005 6:14 am
the filters that come with the short ram are ok with one exception. the end has a fine mesh material yet not fine enought to stop small yet dangerous airborne particles.
I taped off the end, not an engineers approach but it did the trick. BTW, if you see the TRD air filters on ebay, i believe they are fake. I bought one and the car didnt sound 'tough' as it did with the less restrictive air filter.
jazzlara
Postby Jon11582 » Sun Jan 23, 2005 7:29 am
I would get tthe K&N. Ive heard that the filter is the worst part on the cheapo intakes, which is why they set off CELs. The actual design affects performance, and the cheap intakes arent tested for performance either, but I would get a good filter if you really wanna stick with that intake.
Problem is the K&N is going to cost way more than the intake itself. (I think its around 60 bucks for the Xstream K&N, maybe 40 for the regular).
And I dont think theres anyway to make a CAI out of the ebay intakes. The piping ends way to high up on the engine to be able to snake it down to the spot where you need to feed it to the bottom of the engine. It was quite a trip making the CAI out of the Injen intake, so I think its pretty much out of the question for the ebay intakes.
Take a look at my cardomain if you wanna see what the Injen looks like, and how the CAI hooks up on the 5SFE.
2000 Black Solara SE
Jon11582
Postby SEsolara2000 » Sun Jan 23, 2005 9:34 am
i can probably make one of my own but how do you take out that stock plastic vent that is in the fenderwell and ends somewhere under the battery?
SEsolara2000
Postby Jon11582 » Sun Jan 23, 2005 12:36 pm
SEsolara2000 wrote:i can probably make one of my own but how do you take out that stock plastic vent that is in the fenderwell and ends somewhere under the battery?
Gotta take out the battery and unscrew the fuse box and push that out of the way.
As far as I remember anyways.
Jon11582
Postby sunrise_solara » Tue Jan 25, 2005 12:36 pm
SEsolara2000 wrote:ive never seen another solara in my color combo either
There's one on my campus that color combo. I didn't know if it was factory until now. There is also a red/tan combo around here, fugly as hell. I think it is a respray, though. Was the two-tone a factory option, or was it a dealer add-on?
sunrise_solara
Re: ebay intake
Postby TadS » Fri Jan 28, 2005 11:48 am
SEsolara2000 wrote:i got an ebay short intake on my 5SFE solara right now, all the hoses hooked up right i think. Just wondering if i should trash the filter that came with it for a K&N. if its worth it ill get it and if i can make a cold air extension somehow, please give me your ideas on where to put the filter.
Lose the filter, and get a quality one. You can make a CIA extension for that pipe, a guy named Brungold on TN made one from a Civic CAI for his Camry, and I copied his design on mine (which I took off when I put my body kit on.)
TadS
Postby Mandarinsolara » Fri Jan 28, 2005 2:49 pm
im filterless and had clean oil after 5k miles, open box baby. 52.1k miles total now. sounds friggin sweet. dont worry about no expensive filters, its fine
Mandarinsolara
Postby MalBandito99 » Fri Jan 28, 2005 2:59 pm
SEsolara2000 wrote:ive never seen another solara in my color combo either.
Yep, Ive also seen one in South Florida. Most solaras I see here are full of bumper stickers, dents, scratches, or other general abuse. :evil:
MalBandito99
Postby xsolara33x » Fri Jan 28, 2005 3:31 pm
Mandarinsolara wrote:im filterless and had clean oil after 5k miles, open box baby. 52.1k miles total now. sounds friggin sweet. dont worry about no expensive filters, its fine
is that safe or good for the car??? to run without an air filter???
raphael
xsolara33x
