SolaraGuy.com • View topic - Adjusting TRD kit
Adjusting TRD kit
Adjusting TRD kit
Postby thealkimo » Sat Jan 22, 2005 9:42 pm
i just installed my gen1.5 trd kit today and due to my lack of attention i have a small gap (1/8" at most) between one of the valences and my front bumper because the 3m adhesive stuck before i wanted it to, and now it's a too hard to adjust with my bare hands. any suggestions on how to remove the valence and where can i find more of that 3m foam adhesive that came with the kit so i can attempt to re-install?
thealkimo
Postby xsolara33x » Sat Jan 22, 2005 10:01 pm
i dont know the answer to your question sorry bro... but i was wondering where you got your kit painted at and for how much??? i still havent got my kit painted, haha, im need of getting it painted... Let me know bro...
thanks,
raphael
xsolara33x
Postby thealkimo » Sat Jan 22, 2005 10:12 pm
xsolara33x wrote:i dont know the answer to your question sorry bro... but i was wondering where you got your kit painted at and for how much??? i still havent got my kit painted, haha, im need of getting it painted... Let me know bro...
thanks,
raphael
wuts up man...i got my gen1.5 primered kit from Michaels Artic Frost here on the boards and he had it painted for me too for $275 which is bargain since everywhere else would charge me $375+
unfortunately, unless you gotta a major hookup you're prob going to have to spend 4 bills
thealkimo
Postby krawzyazn » Sat Jan 22, 2005 11:40 pm
thanks,
raphael
you have nothing to worry about bro your kit fits PERFECT lolz you got a gen 1 kit remember lolz
Postby xsolara33x » Sun Jan 23, 2005 1:13 am
thanks,
raphael
haha... true... true... just gota be patient... DAMN... I CANT WAIT... haha...
xsolara33x
Postby jazzlara » Sun Jan 23, 2005 6:10 am
ill tell ya kimo, i did the same thing. fortnatly, i was able to pry it off just enough to restick the tape and position it for the two or three aftermarket bolts i put in..
YOu know, there is about 30 pounds of snow and ice grasping to the body kit and it seems to be holding very well.....or atleast until i see them skidding on the highway in my rear view mirror.
When i got my body kit with the premounted tape, i thought "there is no way this is gonna work", but to my amazment, that tape is STRONG. VERY STRONG.
jazzlara
Postby TRD_solaRa » Sun Jan 23, 2005 10:09 am
Yea, I gotta fix the front valance on the drivers side wit some better 3M tape too.
TRD_solaRa
Re: Adjusting TRD kit
Postby Vampire » Sun Jan 23, 2005 11:55 am
It can be tough but you can pull it off. Remember it's poly. The instructions list the 3M tape type to buy if you need to reattach. I can't find my instructions but maybe someone else can help you out if you lost your instructions or threw it away. The only hard part is removing the old stuff. Make sure to do a good job there.
thealkimo wrote:i just installed my gen1.5 trd kit today and due to my lack of attention i have a small gap (1/8" at most) between one of the valences and my front bumper because the 3m adhesive stuck before i wanted it to, and now it's a too hard to adjust with my bare hands. any suggestions on how to remove the valence and where can i find more of that 3m foam adhesive that came with the kit so i can attempt to re-install?
Paul
02 Solara SE V6 5spd SC
00 Camry LE V6 Auto SC
Vampire
Postby Paladin06Greg » Sun Jan 23, 2005 12:07 pm
Just get some lighter fluid and spray it along the seam. Give it about 30 seconds to soak in then pull her off.
Before you reinstall get some 3M adhesive removerr and clean both attaching areas. You can get the 3M tape at any auto parts store. I got mine at Pep Boys.
Good Luck.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby thealkimo » Sun Jan 23, 2005 1:36 pm
Vampire wrote:It can be tough but you can pull it off. Remember it's poly. The instructions list the 3M tape type to buy if you need to reattach. I can't find my instructions but maybe someone else can help you out if you lost your instructions or threw it away. The only hard part is removing the old stuff. Make sure to do a good job there.
Paladin06Greg wrote:Just get some lighter fluid and spray it along the seam. Give it about 30 seconds to soak in then pull her off.
Good Luck.
Thanks for the info...i think i still have the instructions so i will refer back to them and attempt a re-install with new tape :wink:
thealkimo
Postby Vampire » Sun Jan 23, 2005 2:15 pm
Oh, one last hint. Do it when it is hot or the warmest your area gets as the parts do expand a little. This will do wonders in preventing the seams from showing if you did it when the temp was cold and the parts expanded a litlle due to the warmth.
Paul
Vampire
Postby Whatever » Sun Jan 23, 2005 3:47 pm
Vampire wrote:Oh, one last hint. Do it when it is hot or the warmest your area gets as the parts do expand a little. This will do wonders in preventing the seams from showing if you did it when the temp was cold and the parts expanded a litlle due to the warmth.
haha you are hardcore
Whatever
Postby thealkimo » Mon Jan 24, 2005 1:31 am
too bad its not going to be warm for quite some time... :-?
thealkimo
Postby 808Camry » Tue Jan 25, 2005 7:09 pm
the 3m tape you need should say 5lbs strength on it or just have a red backing and the tape itself would be gray.
808Camry
