SolaraGuy.com • View topic - JPP y-pipe question
JPP y-pipe question
JPP y-pipe question
Postby lazyboyz69 » Thu Jan 27, 2005 11:11 am
i think i'm gonna buy the y-pipe that fits on stock headers... anyone have any problems with CEL? and how much hp does it really give out? and is it noticeable power difference with S/C? oh yea one more..... smog legal in Cali? i just barely passed smog just with my s/c.
lazyboyz69
Postby shidosha01 » Thu Jan 27, 2005 12:20 pm
Looks like you're running s/c with 6psi. I recommend you save up a little longer and get the entire JP Performance exhaust system from the headers down to the tail pipe. Warning! IT IS NOT SMOG LEGAL in CA. Call them up and ask for Adam. He may be able to get Jose (the man who fabricates the exhaust system) to do something else for you.
Example from my car:
Last year with 4psi. and Apexi WS Exhaust. I ran 15.1 1/4 mile time.
Two months later with 6psi and JP Performance exhaust system and JP Performance headers. I ran 14.03 1/4 mile time.
Special thanks to original Super Solara owner Ericsol for convincing me to buy the JP Performance system. I couldn't be any happier.
Hope this helps and good luck. 8)
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Postby Mole » Thu Jan 27, 2005 1:47 pm
you will definitely not pass cali smog.
just swap Y pipes when smog time comes.
i had a HC count of 109 vs max allowed of 52. (with custom Y pipe)
with stock Y pipe i got a pathetic HC count of 7. :lol:
perhaps it was the exhaust leak as well.
Postby lazyboyz69 » Thu Jan 27, 2005 2:02 pm
dang... it made that big of a differance... 1 whole second well... with 6psi... ummm....
lazyboyz69
Postby 209solara » Thu Jan 27, 2005 6:52 pm
whats the best ypipe that will actually pass cali smog, and how long would it take to remove if i got the jpp and swaped it out
209solara
Postby 808Camry » Thu Jan 27, 2005 6:57 pm
If you can save up and get the whole system, it's well worth it.
808Camry
Postby shidosha01 » Thu Jan 27, 2005 8:00 pm
lazyboyz69 wrote:dang... it made that big of a differance... 1 whole second well... with 6psi... ummm....
Yes that big of a difference! The stock headers and TRD muffler is restrictive. Don't forget to get some type of EMS too.
shidosha01
Postby Parke10 » Thu Jan 27, 2005 8:54 pm
cali sucks so much ass for smog. id say just get the whole thing and just swap it smog then put if back on.
Parke10
Postby Astro » Fri Jan 28, 2005 2:24 am
^Yeah, but I hear there's going to be a 50 state smog rule. I would have to assume all states will be like Cali.
Postby Fletch » Fri Jan 28, 2005 4:57 am
The JPP set-up looks very nice and has got nothing but positive feedback but it is quite salty. If you are short on funds, perhaps a shop could bend you a custom y-pipe for around $250 or so.
The power gains are huge at the mid and high end.
2006 Legacy GT spec.B
Fletch
Postby DatSRBoi » Fri Jan 28, 2005 6:27 am
Or get one off ebay right now for cheap...I forgot the link but someones selling one used.
Postby Mole » Fri Jan 28, 2005 9:15 am
209solara wrote:whats the best ypipe that will actually pass cali smog, and how long would it take to remove if i got the jpp and swaped it out
stock is the only thing out that can pass smog...
there is no time set for swaping of Y pipes. it jsut depends on how fast one can work.
