SolaraGuy.com • View topic - powerslot or brembos?
Postby 808Camry » Fri Jan 28, 2005 12:43 pm
Which should I get there's about a $20 price diff with powerslot being pricier, both are coated to reduce rust. Which would you guys pick?
808Camry
Postby krawzyazn » Fri Jan 28, 2005 12:44 pm
the reduced rust is bs lol
Postby 808Camry » Fri Jan 28, 2005 12:46 pm
as long as the hub area and outter ring stay clean I know the surface has to eventually wear the plating down so it will rust.
808Camry
Postby krawzyazn » Fri Jan 28, 2005 12:47 pm
also i will be starting the group buy on the brembo's agian very soon if i can find my damn price list lol
Postby 808Camry » Fri Jan 28, 2005 1:27 pm
I actually need them asap, how much can you get them for with out GB? Cause my rear driver caliper froze on me so I need to get a new caliper and also replace both rotors and pads while I'm at it. Let me know what you can do, the slotted & coated brembos on tirerack are 180 shipped.
808Camry
Postby Mandarinsolara » Fri Jan 28, 2005 2:45 pm
im positive the "no-rust area" is the painted part of caliper and disc hub, not the disc braking surface, lol, if you use them , they cant rust.
Mandarinsolara
Postby impactX » Sat Jan 29, 2005 2:47 pm
OEM Toyota
impactX
Postby Jackass-Jeff » Sat Jan 29, 2005 3:06 pm
impactX wrote:OEM Toyota
Just get the ES version =] but then again... it may be too big
1GR-FE ftw!
Jackass-Jeff
