SolaraGuy.com • View topic - Bolt Sizes HELP!!!
Bolt Sizes HELP!!!
Bolt Sizes HELP!!!
Postby Smokeyone22 » Tue Feb 08, 2005 6:33 pm
Anyone who has lowered there car know what size sockets they used to everything.....removing the front and back struts, taking off the old springs to reuse bolts and whatnot off of old struts? Please help i need to make sure i have ALL the right sockets before i start to lower my car cause if i start and dont have them i am basically screwed. Thanks for the help
:D
2001 Solara V6 SE
Smokeyone22
Postby lazyboyz69 » Tue Feb 08, 2005 8:24 pm
you are suppose to reuse old bolts, top and bottom rubber insultor, don't have to cut the bump stop you can if you want to, watch out for the abs line you might brake the senor, i sent you a diagram, jsut basically take out the spring and strut and put the new one in...for the front...
lazyboyz69
