SolaraGuy.com • View topic - quick suspension Q
quick suspension Q
quick suspension Q
Postby jazzlara » Fri Feb 11, 2005 3:50 pm
im putting on tein/tokico combo and have heard about 'cutting the bumpstop' is this a normal practice by auto shops? or is it something you guys do extra to get a good drop?
i want to know cause i may have it professionally installed or installed by a side work mechanic guy. If professionally installed, will they know what i mean when i say 'make sure you cut the bumpstop' ? what is the bumpstop anyway, just for my knowledge?
and ya ya ya, i konw if i search i can find out...but what is the length to cut off?
thanks guys
jazzlara
Postby TadS » Fri Feb 11, 2005 6:14 pm
If you don't have it cut I believe that the strut will hit it when the car bounces normally. You have to shave it down to accommodate the drop. My Intrax springs had me shave 1.5 inches off it, if I remember right (it was 3 years ago LOL).
TadS
Postby jazzlara » Fri Feb 11, 2005 6:18 pm
TadS wrote:If you don't have it cut I believe that the strut will hit it when the car bounces normally. You have to shave it down to accommodate the drop. My Intrax springs had me shave 1.5 inches off it, if I remember right (it was 3 years ago LOL).
hmmm, so is the bumpstop the shaft that comes out of the strut?
jazzlara
Postby TadS » Fri Feb 11, 2005 6:28 pm
It should be connected to the metal shaft. It's the rubber thing that limits downward suspension travel.
TadS
Postby jazzlara » Fri Feb 11, 2005 6:49 pm
TadS wrote:It should be connected to the metal shaft. It's the rubber thing that limits downward suspension travel.
gottcha. thanks
jazzlara
