SolaraGuy.com • View topic - What does it mean if motor oil is flowing from my pcv ....
Postby swimshady906 » Mon Feb 14, 2005 8:56 pm
Into the intake (Injen) ?
02' S2000 Silverstone
swimshady906
Postby JoeB » Mon Feb 14, 2005 11:09 pm
It means you are probably running a supercharger and should check you compression. :o -JoeB
JoeB
Postby swimshady906 » Mon Feb 14, 2005 11:17 pm
Yes on the sc and where should i go to check my compression ... do you think it is too low or what?
swimshady906
Postby swimshady906 » Tue Feb 15, 2005 2:04 am
But i have alot.... ive lost about a quart already.
swimshady906
Postby SC V6 » Tue Feb 15, 2005 6:16 am
oil out the valve cover into the intake = BLOWBY = BLOWN MOTOR = broken piston lands
engine rebuild time
SC V6
Postby Fletch » Tue Feb 15, 2005 6:34 am
Yikes, I get some blow-by out of the air breather I have on the valve cover vent, but I only loose about 3/4 quart of oil every 3k miles.
2006 Legacy GT spec.B
Fletch
Postby SleeperSolara » Tue Feb 15, 2005 7:18 am
Yeah right now when i was cleanin' the bottom half of my intake box, i saw alot of oil near that blowby tubing in the resonator between the rubber hose. :o :o
It's alot on the front rubber hose, and near the opening of the blowby tubing. :o :o
My car only has 65,000 miles i think; it somewhere arounf there.
It's like a thick film of the oil though, not like gushin' into the intake.
Postby Paladin06Greg » Tue Feb 15, 2005 10:37 am
8) Trust me. It's rebuild time. Do it right if you're anywhere in the mid-east coast call Carlos Jr at Arrieta MotorSports. He does it right!! 8)
Keep in mind the longer you drive it that way the more it will ocst to fix it.. :cry:
Ses my web-site for details.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Turbosolara » Tue Feb 15, 2005 10:39 am
it means you have to much pressure on your crack case. check if any vacum line got stucked and if you check compression is fine....just get a oil catch can.
you suppose get some oil from there once awhile but not a quart. i think the quart of oil from gone to somewhere else
Postby adam2562 » Tue Feb 15, 2005 1:53 pm
if u needa new block which is sounds like is what u need then i haev one all it neesd are new rod bearins which are $7 a piece and u need 12... this block from toyota is almost 2,000 i think 1,800... i was gonna use it on my car but then my mexchanic did a compression check and said i didnt need the extra motor cuz my engine was perfectly fine... so i'll sellit to you for $600 its already boxed up in a crate made for it from toyota...
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby swimshady906 » Tue Feb 15, 2005 2:44 pm
Hehe... i appreciate it adam but i acctually have a second block that im planning to build as soon as i get some time.
swimshady906
Postby SC V6 » Tue Feb 15, 2005 3:38 pm
well.... there is no doubt about it.. you need a new motor.. and I'd put money on that
SC V6
Postby JoeB » Tue Feb 15, 2005 8:48 pm
Compression test is very easy and a guage is cheap. Just check the front 3 cylinders since they are VERY easy to get to. Good cylinder compression should be around 225. I think as long as you are above 170 or so, you are ok. My bet is when you take the plugs out of the front 3, you'll find oil on at least 1 of the plugs. You're ring lands are gone. Our pistons are CHEAP aluminum alloy CRAP! I had damaged the ring lands on all 6 pistons. Joseph is right, a little oil in a boosted application is not abnormal. A little positive pressure in places that had vacuum before will do that :wink: . That much oil is definitely a sign of bad thinks, trust me. -JoeB
JoeB
