SolaraGuy.com • View topic - suspension problem - help!
Postby bassthrive » Sat Feb 19, 2005 3:01 pm
Driver's side, everything looks ok...
Passenger's side not lookin so hot. Every time I go over a bump, it squeaks. Needless to say I am taking it back to the shop that did the install. My questions however are what is the proper name for that black rubber piece between the strut and spring? Second, is it easy to re-seat? Do I have to remove my WHOLE back seat AGAIN so they can access the strut bolts or is this something that can be fixed from outside the car?
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby bronzemaxell » Sat Feb 19, 2005 4:06 pm
seat for the spring?
looks like one need to compress the spring with a few thousand pounds of force again to adjust that piece of rubber seat for the spring.
bronzemaxell
Postby TadS » Sat Feb 19, 2005 4:53 pm
You don't need to take it to a shop. I had that happen on one of my rear struts also and used a little bit of elbow grease to re-seat the spring and the rubber thing back into there proper places.
TadS
Postby swimshady906 » Sat Feb 19, 2005 6:22 pm
You do need to take everything out to get to the strut in the back.
02' S2000 Silverstone
swimshady906
Postby bassthrive » Sat Feb 19, 2005 6:43 pm
swimshady906 wrote:You do need to take everything out to get to the strut in the back.
Dont confuse, i know you need to take the rear out to access the strut bolts, i did it once before. I wanted to know if it was required to re-seat the rubber thingy.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby lazyboyz69 » Sun Feb 20, 2005 1:16 am
doesn't look like you need to redo it.... just spring compress it if you can and push it back into place. looks like you went over a mad bump or something and feel out of place.... or wasn't installed correctly.
lazyboyz69
Postby bassthrive » Sun Feb 20, 2005 3:51 pm
Ok, I got it re-seated but the squeak is still there. Any idea what else it might be?
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby TadS » Mon Feb 21, 2005 5:39 am
Is your RSB tight in the bushings?
TadS
Postby bassthrive » Mon Feb 21, 2005 7:45 am
No sway bar, just tokico struts and tein springs.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby bassthrive » Tue Feb 22, 2005 8:40 pm
Problem solved, took the shotgun approach and lubed the hell out of everything.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby camcar se » Fri Feb 25, 2005 8:16 am
I turned my music down today, and when I was driving over a bumpy road I noticed not a big knocking but just a little knocking coming from the rear suspension, I have teins and tokicos, been on for about 1000 miles now Id say, any clue, The rubber looks fine where the spring seats, Im really hoping the mount isnt loose or somthing. Later
camcar se
