SolaraGuy.com • View topic - VSD BASIS install
VSD BASIS install
VSD BASIS install
Postby CASTRO » Tue Mar 08, 2005 4:34 pm
Okay, looking though the for sale section, I noticed that there was a little toy that I might be able to play with... the VSD BASIS. It shows speed and RPM in a nice reflection on your windshield. Looked as much as I could and couldnt find an answer on exactly which wires to tap into.
Wires suggestions needed for tap:
12v & ground...-Allready found em
RPM and Speedo wire sensors. -needed
anyone with knowledge of the wireharness behind the dash please let me know. Thanks! -John
CASTRO
Postby DatSRBoi » Tue Mar 08, 2005 5:14 pm
You have to take and tap into the dash needles circuts on the back. The rpm is the negative one in the back right behind the rpm gauge part on the circut. The speed should be the same behind the speed section. Hope that helps. Tooked me 5 hours to figure out mine.
Edit:Careful when taping. Its not fun if you see a puff!!
Postby CASTRO » Tue Mar 08, 2005 5:17 pm
ohh thanks that sorta helps. is there a way that i can instead tap into a waire from the harness instead of the circuit system in the guage cluster? I've installed indeglows before and I dont think i wanna take apart the needles or mess with it. thanks again
CASTRO
Postby Turbosolara » Tue Mar 08, 2005 5:32 pm
you can also tape wires from near ecu, i am sure some people has pin out for the 1mz ecu.
Postby CASTRO » Tue Mar 08, 2005 5:43 pm
i have the ECU pin layout but am currently having a hard time deciding on which one it would be. I would post up the picture but im sure there is a post somewhere here that should still have it. My guess is that it might be one of the ones that is marked "idle" since on the pin layout that I got there is more than one. thanks for all your help guys
CASTRO
Postby DatSRBoi » Tue Mar 08, 2005 5:46 pm
Wow..No one ever helped me out on that awhile back when I asked.. :(
Postby krook » Tue Mar 08, 2005 6:00 pm
offhand, i know the tach is orange/black behind the glovebox if you need that wire. . .
krook
Postby CASTRO » Tue Mar 08, 2005 6:01 pm
krook wrote:offhand, i know the tach is orange/black behind the glovebox if you need that wire. . .
oooo thanks! now another suggestion for the speedo wire then im set! :roll:
CASTRO
Postby krook » Tue Mar 08, 2005 6:19 pm
well what wire are you looking for then, sarcastic-ass?
krook
Postby dan99solara » Tue Mar 08, 2005 9:13 pm
he wasnt being sarcastic. he was thanking you. A$$.
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
Postby CASTRO » Tue Mar 08, 2005 10:27 pm
dan99solara wrote:he wasnt being sarcastic. he was thanking you. A$$.
true, thanks for the backup dan99solara. sorry krook if it sounded that way but I dont really have time to post up sarcatsic jibberish, I just wanted direct answers and thank you again for your help. It was much appreciated.
CASTRO
Postby WTF?? » Wed Mar 09, 2005 12:20 am
^Lier!! :lol: :lol:
Retired... its been fun Image
WTF??
Postby CASTRO » Wed Mar 09, 2005 1:32 am
hahaha :drinking:
CASTRO
